If the heater is blowing air you dont need to check the fuse - its working
Does the temp guage show the engine is running at normal temp ? How long does it take to get to temp ? Even if the stat is faulty it will still blow hot air just take a lot longer to do so.
If the car is running hot while normal driving - could be water pump
If non of them you might either have a blocked heater motor or the heater controll for the temp could be broken
