Author Topic: 2002 V6 Auto  (Read 2459 times)
Offline benvictors
  • bgk Tuning - coming soon!!!
Re: 2002 V6 Auto
« Reply #10 on: 23 January 2012, 21:15 »
Cheers Danny, think the MAF is ok now, after cleaning it out and re-installing it hasn't come back up on Vag-Com and the van is running pretty good. Think I will change the Lambda tho, its still using a lot of fuel, I know the Van is a lot heavier than my VR and it has an extra 12 valves, but if I can get 50-55 miles from a tenner of fuel, then surely I should be able to get 35-40 from the van?!?!  :undecided:
What do you mk4 V6 boys/girls get mpg wise??
Just changed the coding on the Auto box for economy mode too, see if this makes a difference.
Offline benvictors
Re: 2002 V6 Auto
« Reply #11 on: 23 January 2012, 21:20 »
Also, am I likely to have pre and post Lambda's? I will have a look tomorrow to be sure but arsed going out now for a look  :grin:
Offline danny_p
Re: 2002 V6 Auto
« Reply #12 on: 23 January 2012, 21:59 »
2002 your likey to have both TBH
the first one is the more expensive as its quite likely to be a wideband , if it is it's even more inportant that its functioning correctly as the ecu monitors it closely under all driveing conditions and uses it to trim fueling accordingly,  also any exhaust leack upstream of it will reack havock with drivablity/ power and economy.
the 2nd lambda is used but is no where near as inportant it's more there just to monitor things and keep a check on the cat, bounus is the 2ndry lamda will be a narrowband  and cheeper
all the VW's have gone bar 1.
Offline tshirt2k
  • Been there...Done that...
Re: 2002 V6 Auto
« Reply #13 on: 23 January 2012, 23:00 »
If you're getting a new lambda sensor. Try lambdapower. Good service and prices.
Mk3 ABF 16VT Megasquirt V3
Offline benvictors
Re: 2002 V6 Auto
« Reply #14 on: 23 January 2012, 23:26 »
Cheers Danny, Cheers Russ, I'll give em a try :cool:
