Author Topic: Funkyfive and his Golf Mk3 Cupra R (1.8T BAM on Emerald K6)  (Read 66521 times)
Offline VR6_Wherry
Re: Funkyfive and his Golf Mk3 Cupra R ride
« Reply #40 on: 24 January 2012, 13:31 »
A little gutted that you've decided to bin the VRS, was following it on the VR6OC. Although it's an exciting alternative that you have picked! :cool:
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #41 on: 24 January 2012, 18:26 »
Superchargers just bore me so much ZZZZzzzzzzzz
Turbo all the way
Matin, the Thing i got from TPS that you arranged for me haha.... got a reeeet story to tell u :laugh: :lipsrsealed:
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline funkyfive
« Reply #42 on: 24 January 2012, 20:48 »
Today's update, Old engine out, Emerald ECU and loom fully integrated. Clocks and remaining parts from TPS due, then it's the next phase lol
The Emerald Ecu and loom, does that connect to any of the original loom?
Thats not bad going for a days work  :cool:
Yeah it connects to some parts of the engine loom, not sure which connections but will find out?
Offline stow1985
  • 'when im cleaning winders'
« Reply #43 on: 24 January 2012, 20:50 »
Interesting...
Offline funkyfive
« Reply #44 on: 24 January 2012, 20:52 »
Thanks fella, it's strange going to 4 cyl but 1.8t BAM with tweaks gives me a unique drive. Are you interested in the charger lol?
Offline funkyfive
« Reply #45 on: 25 January 2012, 08:34 »
First vid clip of the engine running.
http://www.lovemelongtime.co.uk/?p=263
Offline VR6_Wherry
« Reply #46 on: 25 January 2012, 13:27 »
Shameless plug! I love it  :grin:
If i wasn't saving my money to go travelling then i would have taken the whole engine, box and charger from you! :grin:
Offline Toby
  • Car - less
« Reply #47 on: 25 January 2012, 21:36 »
sounds sweet martin!
been driving it tonight?  :laugh:
Currently down under
Offline funkyfive
« Reply #48 on: 26 January 2012, 08:40 »
Hey Toby, no mate, but...Ben did take her out. She is running a conservative 10 psi at the moment and we will be pushing her up to 18 psi +. This is not peak boost.
Offline funkyfive
« Reply #49 on: 26 January 2012, 20:25 »
18 psi is the max, I will run. So the plan is to sort the rear engine mount out as its knocking and check out the boost pipes for moment. I also still need to wire in the EGT sensor and wide band.
JDM are going to map it, I will run close looped with a wideband lambda instead of adaptive mapping. From what I understanding adaptive mapping makes live changes to the ECU and the closed loop setup with wideband can be set with 10% threshold so it's allow some protection to prevent detonation.
Lots to learn but I m looking forward too it!
Power wise I looking for 250 - 260 bhp, 280 ft lb. So it's similar to a stage 2 revo map.
