Author Topic: Funkyfive and his Golf Mk3 Cupra R (1.8T BAM on Emerald K6)  (Read 66470 times)
Offline funkyfive
Re: Funkyfive and his Golf Mk3 Cupra R ride
« Reply #20 on: 22 January 2012, 20:47 »
Brad and Russ, its all about the "BOOST" lol.
Offline funkyfive
« Reply #21 on: 22 January 2012, 20:51 »
looks HOT HOT HOT, why not lighten the flywheel?
I am not a mechanic, just a player but the lighten flywheel you gain and lose some benefits. E.g. the engine is more free revving but on hills you loose some power due to the reduced mass.
But if you got it balanced with a clutch, I am guessing is more harmonic and you reduce plate friction?
Again I am not 100% sure, but thats my basic understanding.
Offline sharki786
  • GOT BOOST??
« Reply #22 on: 22 January 2012, 21:04 »
ive had my flywheel lightened and balanced and it revs like a C*NT! but mine is an 8v
*****MK3 Anniversary*****
*****MK4 GTI T*****
« Reply #23 on: 22 January 2012, 21:18 »
I would stick with the VR6 engine  :smiley:
Offline funkyfive
« Reply #24 on: 22 January 2012, 21:21 »
Hi Wayne its been a long time since I last spoke to you. You had a sick MK3 8v, painted, vento front and dropped.
I'm done with the VR tbh. I am looking forward to the challenge of a 1.8T.
« Reply #25 on: 22 January 2012, 21:22 »
I never had a Vento front  :smiley: good luck with the conversion :afro:
Offline funkyfive
« Reply #26 on: 22 January 2012, 21:29 »
lol must be age, was some years back and thanks I am also hoping the conversion is successful its my daily driver.
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #27 on: 22 January 2012, 21:32 »
Once you go bam you never go back wahahaha...   (re the phone call / Mac ) :laugh:
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline tshirt2k
  • Been there...Done that...
« Reply #28 on: 22 January 2012, 21:48 »
You have to rev a bit more to pull away but thats the only downside and you get used to that pretty quick. You dont lose power/torque, but you will have enough on tap anyway, and you won't be spending much time between 1000-1500rpm anyway.
Less mass to rotate makes it rev quicker and acts as if the car is lighter.
An 02A flywheel gets balanced on its own.
Here what i had done. From around 10kg to around 5.5kg
Mk3 ABF 16VT Megasquirt V3
Offline funkyfive
« Reply #29 on: 22 January 2012, 21:51 »
Kool who did the work for you and did you get the clutch balanced as well? I might have this done when I get another box to rebuild and put in an LSD. This is a long way off lol need to get her running first.
