Author Topic: water/meth inj fitted and it's awesome.  (Read 2202 times)
Offline shaft69
« on: 21 January 2012, 23:44 »
Fitted my water/meth inj kit at last,very impressed progressive kit with 8 psi spray start. So much power difference on midrange its unreal few more tweeks fabriced cooler to throttle housing being made. Also fit forge turbo actuator and then custom spec 2 r-tech map. Just love it.  :smiley:
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Chris.
Re: water/meth inj fitted and it's awesome.
« Reply #1 on: 22 January 2012, 02:21 »
What power you make....got a graph and other mods?
Click For Build Thread
Offline shaft69
« Reply #2 on: 22 January 2012, 10:29 »
At mo running APR stage1 map,APR d/p with sports cat, milltek cat back, forge tip and boost pipes, oo7 dp, tyrolsport smic. To be fitted c20let yellow inj, forge actuator, mod throttle intake to fit meth inj nozzle. Never been on rollers. Compared to last mk4 agu with r-tech map that was 197bhp this leaves it for dead. Raced mate in his focus st couple weeks ago couldn't catch me to 125mph. Really impressed with APR map be honest really peaky. Poss going for power run sat at carbon if can fit me in.
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #3 on: 22 January 2012, 11:05 »
Get a graph up!!
Offline jonrandom
« Reply #4 on: 22 January 2012, 11:09 »
Good stuff mate that sounds good hope my aquamist works as well. Which kit did you get in the end?
Offline Chris#101
« Reply #5 on: 22 January 2012, 11:11 »
sounds good  :cool: have to shove a graph up!
How hard was it to fit the actuator? and how did you set it up!? as ive got to do mine before heading to r-tech
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Chris.
« Reply #6 on: 22 January 2012, 12:13 »
Actuator pretty easy to do, apart from the last bolt behind oil line banjo.  Theres a setup video I made on youtube.
Shaft, is that still on a k03 turbo or a k03s?
Offline Chris#101
« Reply #7 on: 22 January 2012, 15:40 »
Cheeers just watched it on youtube, setting up seems simple enough!
Can you change the actuator with  the turbo still on the car?
Offline shaft69
« Reply #8 on: 22 January 2012, 15:59 »
AUM with ko3s with my mods at mo my best mate driven mine says faster than his 225tt. Will get graph as soon has get it on rollers. Ring carbon tomorrow if can fit me in weekend.
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline bobbarley
  • I'm kind of a big deal...
« Reply #9 on: 22 January 2012, 16:03 »
How much has your insurance gone up by adding that kit?
