Author Topic: t4 cam belt snap  (Read 1466 times)
Offline ENERGY
t4 cam belt snap
« on: 21 January 2012, 23:01 »
Anyone here know how much new valves cost, my mates got a 2.5tdi t4 which has just snapped a cam belt and hes giving it to me but we dont yet know the extent of the damage...
I take it its probably f**ked but then my caddys cam belt snapped and it was fine with a new belt on !
Anyway im getting it cheap so i dont mind have a tinker wiv it myself! keep me out of trouble for a while. How much roughly would it cost to fix if it was proper f**ked??
Offline sharki786
  • GOT BOOST??
Re: t4 cam belt snap
« Reply #1 on: 22 January 2012, 01:00 »
have a look on AUTODATA to see if the engine is interference (will bend valves) or non interference (wont bend valves)
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline danny_p
« Reply #2 on: 22 January 2012, 11:57 »
diesels always hit,   iirc it's a twit of a job on a t4,
valves themselves are quite cheep scrap heads to pillage bits from are cheeper still,  but i would really recommend  dial gauging the the tops of the pistons before trying to fix it,  just to make sure there all still coming up to where they should.  depending how hard it decided to hit it may just need a couple of valves or it chould be valves, rod, piston, con rod, tappets, cam even cyl head
all the VW's have gone bar 1.
Offline ENERGY
« Reply #3 on: 22 January 2012, 19:39 »
cheers folks ill look into it
towing the van home this week sometime !
Offline justalex81
« Reply #4 on: 23 January 2012, 06:50 »
as a minimum you're going to need:
valves
cam belt
water pump
head gasket
head bolts
inlet & exhaust manifold
may aswell change the thermostat while you've got the system drained
oil and filter
new coolant
i'd say you're looking at at least £300
Offline ENERGY
« Reply #5 on: 25 January 2012, 19:01 »
That aint to bad then is it Got her on the drive atm tidied my garage up and sorted all my tools out, just need a bit of spare time now ;)
