Author Topic: dreaded boost leak (FIXED) :)  (Read 9160 times)
Offline james2
  • No scammers please.
Re: dreaded boost leak
« Reply #30 on: 22 January 2012, 00:16 »
A months good .Had pulse plugs fail in 6 miles ( 2 sets). Ngks best (PFR6Q)but its wont be the cars fault. UNLESS there nology silver they jurk on boost (stage 1 map). :sad: But never failed. Cant beat ngk. :smiley: AGUS LOVE ngk OR Bosch 4S  (but never used them) ( i class them as cheap). :lipsrsealed: Years back max power showed the gains of plugs bosch 4 , they sucked but do there job well.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline james2
« Reply #31 on: 22 January 2012, 00:20 »
My amp had no code.  :wink:
Offline pickles
  • Next!!!
« Reply #32 on: 22 January 2012, 00:24 »
il check the plugs n that whilst i wait on the code reader or find sumwr to test it for me
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline barrym381
« Reply #33 on: 22 January 2012, 02:06 »
ur welcome to use my code reader if u can drive 20mins from u  :smiley:
Offline pickles
  • Next!!!
« Reply #34 on: 22 January 2012, 06:20 »
thanks for the offer m8, wr bouts are u like
Mapped
Nearly S3 time  :)
Offline pickles
  • Next!!!
« Reply #35 on: 22 January 2012, 07:01 »
just done a MAF test, unplugged it whilst running, didnt appear to do anything, does that mean anything
Mapped
Nearly S3 time  :)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #36 on: 22 January 2012, 10:23 »
does the car try to stall when you plug it back in?
Offline barrym381
« Reply #37 on: 22 January 2012, 12:08 »
2 mins from erskine bridge :smiley:
Offline pickles
  • Next!!!
« Reply #38 on: 22 January 2012, 22:07 »
didnt have time to do anything tonight but yes it started going erratic when i plugged it bk in, and nearly stalled.  when i initially start the car, the revs will hold at 1250 for a few seconds then drop to 1000 and jump up n down a few times before goin dteady again, this seems like a commom cycle its doing
« Last Edit: 22 January 2012, 22:19 by pickles »
Mapped
Nearly S3 time  :)
Offline pickles
  • Next!!!
« Reply #39 on: 22 January 2012, 22:20 »
thats miles away m8 lol, shud have a diagnostics reader  mon/tuesday hopefully, busy as fk til then anyway
Mapped
Nearly S3 time  :)
