Author Topic: dreaded boost leak (FIXED) :)  (Read 9157 times)
Offline pickles
  • Next!!!
« on: 21 January 2012, 16:50 »
driving today and everything was fine till my rear passenger side tyre mounted the kerb, i now have a boost leak, gauge isnt getting above 1.5 psi, im assuming a hose has came loose somewr, car drives fine but every now n again it will judder etc, any1 any pointers in wr to start here :)
« Last Edit: 25 January 2012, 21:06 by pickles »
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline pickles
  • Next!!!
Re: dreaded boost leak
« Reply #1 on: 21 January 2012, 17:49 »
checked all hoses visually and all seems fine, noticed car seems ruff on idle now as well with rev fluctuations, if the car has went into limp home mode, do i need to reset the ecu to get back out or is it automatic
Mapped
Nearly S3 time  :)
Offline mcgee9t2
« Reply #2 on: 21 January 2012, 17:57 »
i belive that you need a code reader to erase any codes to get it out of limp mode?
ide turn the car on and try listne out for any boost leaks too (might be hard over engine noise)
Offline pickles
  • Next!!!
« Reply #3 on: 21 January 2012, 18:02 »
i see, that wouldnt explain the bad idling tho eh, have tried to listen and feel for any leaks, cant find any
Mapped
Nearly S3 time  :)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 21 January 2012, 18:03 »
bad idling will be a leak somewhere, pulling in un-metered air
Offline mcgee9t2
« Reply #5 on: 21 January 2012, 18:05 »
could just be a tiny leak.
perfect time to upgrade hoses  :wink:
Offline pickles
  • Next!!!
« Reply #6 on: 21 January 2012, 18:26 »
iv upgraded a few but checked all those n they seem fine :(
Mapped
Nearly S3 time  :)
Offline mowlamb
  • MK4 GT TDI 130 - DERV POWER!!
« Reply #7 on: 21 January 2012, 19:14 »
I may be wrong but I think limp mode goes off when you turn the car off. Obviously if whatever caused it happens again once you start her up again then it will go back into limp mode until switched off again. I was switching the car off and starting it up again whilst moving when I had the problem with mine.
Offline james2
  • No scammers please.
« Reply #8 on: 21 January 2012, 20:10 »
Did you hit the kerb hard.? Does you car sound like its running on 3 cylinders. You got agu with a cai, you know what i think it is.  :wink: ign amp.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline pickles
  • Next!!!
« Reply #9 on: 21 January 2012, 20:13 »
didnt think it was too hard tbh,on start up its ruff then idles for a while and then goes ruff again, , its actually cutting out now, have checked the ignition amplifier, seems ok, but my experience with them is limited lol
Mapped
Nearly S3 time  :)
