Author Topic: AGU: were does this wire connect too?  (Read 3808 times)
Offline james2
  • No scammers please.
« on: 21 January 2012, 00:13 »
I found it unpluged ? :undecided:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline blade4real2004
  • golf gti with a touch of .:R
Re: AGU: were does this wire connect too?
« Reply #1 on: 21 January 2012, 01:50 »
At a guess I would say power steering switch can't see clearly from that pic
k04s | jabba cai | stage 2 (Rtech) | forge 007p | forge boost hose set |forge tip | THS fmic | gen r line kit | bbs ch | TT short shift | R32 vents | full stainless | decat | auto windows | mk5'd boot
need a scan or mod with vagcom & vagtacho PM ME (south wales area)
my build thread - http://uk-mkivs.net/forums/t/236415.aspx?PageIndex=1
Offline Alan16ac
« Reply #2 on: 21 January 2012, 01:57 »
That's my engine bay? Lol
Offline pickles
  • Next!!!
« Reply #3 on: 21 January 2012, 12:32 »
sure its not the main cable going to the alternator
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline Dave_IOW
« Reply #4 on: 21 January 2012, 14:59 »
You really need some new clamps for your pipework. That must be leaking like mad.
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline Alan16ac
« Reply #5 on: 21 January 2012, 15:14 »
Lol I know!
I bought it like that, and I've been told by many members on here now.
It's being sorted  :embarassed:
Offline barrym381
« Reply #6 on: 21 January 2012, 15:17 »
1st time i have saw exhaust clamps used there :laugh:
Offline Chris.
« Reply #7 on: 21 January 2012, 15:57 »
Theres 4 things that go down there
Main feed to alternator (bit black cable)
The Alternator battery light switch
Air con wiring (if fitted)
Power steering switch.
Click For Build Thread
Offline james2
« Reply #8 on: 21 January 2012, 20:16 »
i was thinking air con or power steering. Put iv looked for the part to plug it in, i cant see it.  :undecided:
Offline Alan16ac
« Reply #9 on: 21 January 2012, 20:33 »
Well the wire you're pointing to on my car definitely isn't air con as it doesn't have air con.
