Author Topic: Change Atmospheric DV for Recirc Valve Help!  (Read 1436 times)
Offline Alan16ac
« on: 20 January 2012, 21:05 »
Okay, so I've been informed that my car has an atmospheric DV and this isn't good!
How hard is it to change this for a Recirc Valve?
Here's the valve that's on it, please help asap, as I'm worried now lol!
Offline daz veedub
  • Operation 1.8t bolf
Re: Change Atmospheric DV for Recirc Valve Help!
« Reply #1 on: 20 January 2012, 21:33 »
dv valve sits into the tip theres a pipe coming of the dv onto the charge pipe and a 3/4mm pipe coming out the top, route that to the fuel pressure regulater if u need any pics go through my dub rides thread
http://www.golfgtiforum.co.uk/index.php?topic=183466.0
probaly best starting from the last page workig back quite few engine pics there  :smiley:
Offline james2
  • No scammers please.
« Reply #2 on: 20 January 2012, 21:36 »
Its easy to change. Get a forge 007 (with yellow spring). What are the exhaust clamps on (a boost pipe). If so change them. You could be loosing boost there.  :wink:
« Last Edit: 20 January 2012, 21:39 by james2 »
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline Alan16ac
« Reply #3 on: 20 January 2012, 21:39 »
Its easy to change. Get a forge 007 (with yellow spring).It sits in were yours is ,straight. What are the exhaust clamps on (a boost pipe). If so change them. You could be loosing boost there.  :wink:
Yes I hadn't even noticed the exhaust clamps, going to change them Asap, and order a Forge 007 on the 28th (payday).
Offline james2
« Reply #4 on: 20 January 2012, 21:44 »
Have a good look over your boost pipes and change all the exhaust clamps. Your DV will be fine until you get a forge one .I used to run blowoff valve on my AGU .But you dont know what spring is in it. Yours must be mapped to get 11psi so get a yellow spring with it.  :wink:
Offline daz veedub
Offline Alan16ac
« Reply #6 on: 20 January 2012, 21:53 »
Okay, will order that asap.
Am I going to be able to fit it myself, I'm NO mechanic!
Shall I use hose clamps for the pipes?
Offline james2
« Reply #7 on: 20 January 2012, 21:54 »
this 1  :smiley: from awesome gti
http://www.awesome-gti.co.uk/product.php?xProd=3714&xSec=9920
what spring would he need. I have yellow on stage 1 ,but it says green 8-15 psi ,yellow 15- ?? psi.  :undecided:
Offline james2
« Reply #8 on: 20 January 2012, 21:55 »
  YES  :wink:
