Author Topic: Rust !!  (Read 2270 times)
Offline golfmanj80
Rust !!
« on: 20 January 2012, 18:40 »
Just washed the GTD today, while cleaning wheels noticed some rust marks on disc hub, just where it meets the wheel,
Is this normal, best course of action to resolve ??
Golf GTD, Tornado Red, 3 Door, 2009, DSG, Vancouver 18", Satnav, Dynaudio, ACC, Winter Pack,
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: Rust !!
« Reply #1 on: 20 January 2012, 18:51 »
Galvanic corrosion between alloy wheel and brake disc. This is just normal, maybe a clean up with a wire brush and bit of copper grease next time the wheel is off will somewhat prevent it.
Jimmymature
Re: Rust !!
« Reply #2 on: 20 January 2012, 19:15 »
Yep, this is normal on the Golf.
Jim
Offline SRGTD
Re: Rust !!
« Reply #3 on: 20 January 2012, 19:30 »
Jim
Normal on many other makes of car too. If it concerns you, you could paint them with Hammerite or something similar next time you have the wheels off.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline golfmanj80
Re: Rust !!
« Reply #4 on: 20 January 2012, 20:12 »
Thanks for the replies guys, I think the issue is highlighted by the open format of the vancouvers, prob need for hammerite as will play on my mind !!
Offline R32UK
Re: Rust !!
« Reply #5 on: 20 January 2012, 21:37 »
try a search on the mk5 board as I remember someone doing this with a very good write up.  :cool:
Offline JC
  • Back in the North.
Re: Rust !!
« Reply #6 on: 20 January 2012, 22:47 »
 :shocked:
 :lipsrsealed:
Offline PenguinGTI
Re: Rust !!
« Reply #7 on: 20 January 2012, 22:57 »
:shocked:
 :lipsrsealed:
Shut it  :grin:
Nah, back to the OP, don't worry. It's common across all VAG cars near enough. It may not be as common on GTI's as the owner's will likely look after their cars but have a look at the next Audi A5 2.0TDI repmobile you see and it will be the same (probably worse).
