Author Topic: Turbo Nut/bolt, cant get it off  (Read 3462 times)
Offline pickles
  • Next!!!
Re: Turbo Nut/bolt, cant get it off
« Reply #20 on: 13 July 2012, 22:56 »
Use a spanner lol.
Some you can get with socket + lots of extensions from underneath,
cheers bud, wee stressful job for a sat mornin :) lol
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #21 on: 14 July 2012, 12:14 »
I did mine at work so I had the use of my mates tool box which has about 6k worth of tools in it so it made everything a bit easier, even when I cross threaded one of the bolts  :embarassed:
Offline pickles
  • Next!!!
« Reply #22 on: 14 July 2012, 20:49 »
big praises for stubby spanners :), managed to get a few more turns on it and it sounds a lot better at idle, however its not fully tight as there is movement in the washer. may just have to change the nut,add a couple of washers, am i right in sayin its an M10
Mapped
Nearly S3 time  :)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #23 on: 14 July 2012, 21:32 »
Little tip for you, get it up on axle stands then jack the turbo up gently, at least then you're just working the bolt in, not trying to lift everything up with the bolt  :wink:
Offline pickles
  • Next!!!
« Reply #24 on: 15 July 2012, 14:28 »
thanks m8, its the downpipe to turbo tho, could jack up the downpipe i suppose tho for the same effect :).
is it M10 ppl
Mapped
Nearly S3 time  :)
