Author Topic: Turbo Nut/bolt, cant get it off  (Read 3461 times)
Offline blade4real2004
  • golf gti with a touch of .:R
Re: Turbo Nut/bolt, cant get it off
« Reply #10 on: 21 January 2012, 14:51 »
spanners is how i do it mate put a ring spanner on the end of the nut then put a spanner on the end of the spanner to give you some extra lever lenth
thats how i do it and works a treat i undo it and then do it up real tight with a spanner on its own never have any problems doing it this way
k04s | jabba cai | stage 2 (Rtech) | forge 007p | forge boost hose set |forge tip | THS fmic | gen r line kit | bbs ch | TT short shift | R32 vents | full stainless | decat | auto windows | mk5'd boot
need a scan or mod with vagcom & vagtacho PM ME (south wales area)
my build thread - http://uk-mkivs.net/forums/t/236415.aspx?PageIndex=1
Offline houston
« Reply #11 on: 22 January 2012, 20:19 »
use a spanner and it comes off fine.
make sure it is 16mm, if anyones had it off and changed it with a generic bolt then itll be a 17mm head, mine was
Offline pickles
  • Next!!!
« Reply #12 on: 22 January 2012, 22:13 »
thnaks guys, will give it a bash once i get my other issue sorted lol
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline pickles
  • Next!!!
« Reply #13 on: 09 February 2012, 17:06 »
its fkn finally fkin off woo hoo lol
Mapped
Nearly S3 time  :)
« Reply #14 on: 09 February 2012, 17:42 »
how you do it in the end?
Offline pickles
  • Next!!!
« Reply #15 on: 10 February 2012, 00:14 »
garage did it for me £10er,  :grin:, exhaust will defo be fitted tomoro :)
Mapped
Nearly S3 time  :)
Offline pickles
  • Next!!!
« Reply #16 on: 13 July 2012, 22:01 »
guess what, cant get the f**k*r bk on right :( lol, was fine for ages now its blowing n i need to tighten this MOFO up.
cause of the twisted design of the downpipe i cant get a socket on it.
thinkin the only way is with a stubby spanner unless any1 else has any suggestions
Mapped
Nearly S3 time  :)
Offline Chris.
« Reply #17 on: 13 July 2012, 22:05 »
17mm spanner. ONly get like 1.8th turn on it but you can get to it.
Click For Build Thread
Offline pickles
  • Next!!!
« Reply #18 on: 13 July 2012, 22:14 »
re used the old 16mm nuts m8,  could get to it with a stubby spanner for sure, just wondering if any1 has any tricks of the trade lol without having to melt a socket onto it  :laugh:
Mapped
Nearly S3 time  :)
Offline Chris.
« Reply #19 on: 13 July 2012, 22:23 »
Use a spanner lol.
Some you can get with socket + lots of extensions from underneath,
