Author Topic: My New 16Valve  (Read 1495 times)
Offline Neaty
My New 16Valve
« on: 16 May 2005, 20:08 »
I have fairly recently bought a valver off ebay (£255!) and after driving 280 miles back home from where i bought it from it was fine, didn't need to stop at all.(apart from petrol obviously)
Got it home and just hours after getting it back it i decided to take it for a spin where it overheated. After replacing the thermostat it seems to be ok, but when driving in traffic it gets a bit hot for my liking! the water temperature needle sits half way up but now and again it will get to about 3 quarters the way up.
Is this normal?
it is an 1987 on an E plate small bumper model if that helps
Paul
Offline tinman
Re: My New 16Valve
« Reply #1 on: 16 May 2005, 22:03 »
Its not normal. As long as it doesnt flash red your okay for the time being.
You might want to check the radiator fan is coming on.
Offline piggy
  • What you lookin' at sonny?
Re: My New 16Valve
« Reply #2 on: 16 May 2005, 22:57 »
Give the whole system a good flush out then fill it up makeing sure you have the correct amount of Anti Freeze in there as it makes a difference to the temp of the system cos of it's cooling properties. :smiley:
Offline Gambit
Re: My New 16Valve
« Reply #3 on: 17 May 2005, 09:22 »
the higher the concentration of anti freeze you put in the car the less the cooling properties of the system :wink:
just do about a 50/50 mix of antifreeze & water. if you can, use de-ionised water
Re: My New 16Valve
« Reply #4 on: 18 May 2005, 10:47 »
Half way is normal operating temperature, and 3/4 is nothing to worry about if you're sitting in traffic.  As long as the fan is kicking in when it gets to about 3/4 then your cooling system is functioning perfectly :)
Only if the light starts flashing or if it goes higher than 3/4 you should worry :)
Offline Neaty
Re: My New 16Valve
« Reply #5 on: 22 May 2005, 18:37 »
thanks guys, i will try the anti freeze idea
( FYI: the red light doesn't flash and the fan does kick in when water temp needle is at about 3/4 way up)
cheers
paul
Offline T1 VDUB
  • All work and no play makes Jack a dull boy
Re: My New 16Valve
« Reply #6 on: 23 May 2005, 22:11 »
eeeerrrrrmmmmm, quick question without hijacking your thread!!! :shocked:  :shocked:
My light always flashes red... from start up to running warm. I assumed it was a faulty sensor which I am due to check or am I about to meet my maker in a ball of flames?  :undecided:
16 Valve
Re: My New 16Valve
« Reply #7 on: 23 May 2005, 23:58 »
That happens if the level sender in the header tank is unplugged or broken, try bridging the pins to see if that stops it flashing :)
