Author Topic: mk3 electric window advice needed!  (Read 2314 times)
Offline timmy7hands
« on: 19 January 2012, 02:13 »
I have a '97 mk3 16v, and for a while now the driver side window refuses to budge! I can hear what sounds like the motor whwn i press the switch either up or down, but no movement  :sad: . I just thought i'd see if anyone could shed some light before i start taking apart the doorcard and pretending to know what i'm doing.
any help would be greatly appreciated.
Cheers!
Offline Deano2711
  • 1992 VR6
Re: mk3 electric window advice needed!
« Reply #1 on: 19 January 2012, 07:21 »
Sounds like you need a new mechanism which is common. You can pick one up pretty cheap in the breaking section.
Offline madmanmart
« Reply #2 on: 21 January 2012, 18:15 »
Snapped wire in the A pillar rubber boot.
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline Deano2711
  • 1992 VR6
« Reply #3 on: 21 January 2012, 20:40 »
He said he could hear the motor running when he pushes the switch so a snapped wire in the mechanism maybe ??
Offline mad4vws
« Reply #4 on: 21 January 2012, 20:58 »
sounds like the cable has snapped and  tangled , it is running up and down the plastic grommet with groves  common problem on these. :smug: :smiley:
BREAKING VW GOLF'S
Mk2/ MK3'S ALL DAY LONG. PM FOR ANY PARTS!!  ON 07813936583
Offline madmanmart
« Reply #5 on: 22 January 2012, 00:47 »
Depends, if the earth wire is snapped the motor just makes a small noise.
Offline Seanl
« Reply #6 on: 22 January 2012, 09:34 »
Been asked about a million hundred gazzilion and twelve times. Use the search function.
Offline dan_apps
  • too low for british roads!
« Reply #7 on: 22 January 2012, 10:56 »
cheapest way to do it is to buy the frame, wire and runners off ebay, there is a guy who sells it as a kit and use your old motor if the guide roller isnt all chewed up. people breaking them still want about 50 quid for them.
Offline timmy7hands
« Reply #8 on: 26 January 2012, 01:32 »
 Thanks for all the help peeps!
will be checking it out tomorrow as i finally have a day out from teaching :smiley:
will post to let you guys know the outcome soon. needs doing though, as it makes using ticket-entry car parks a right old pain in the ass!
