Author Topic: CV joints  (Read 1537 times)
Offline gizago
CV joints
« on: 18 January 2012, 19:54 »
My inner CV joint exploded on the way home from work the other day :rolleyes:, which got me thinking- are there any direct replacements from the vag line up that would be stronger?? Would for example mk3 tdi cvs fit, or passat??
Cheers, Mat.
Offline dan_apps
  • too low for british roads!
Re: CV joints
« Reply #1 on: 18 January 2012, 19:57 »
was it greased up fine? boot not slit/ cut in any way?
i had one from GSF which seemed very good quality and lasted until the car was off the road, not sure there is need to go to a different fitment!
Offline gizago
Re: CV joints
« Reply #2 on: 18 January 2012, 20:21 »
Havent had the chance to look at it properly as it was dark when it happened, and is dark by the time I get in, but it was greased up, boot was fine, bolts all tight etc.
Offline Sam
  • Sam I am
Re: CV joints
« Reply #3 on: 18 January 2012, 20:26 »
They always are  :lipsrsealed:
Offline danny_p
Re: CV joints
« Reply #4 on: 18 January 2012, 21:50 »
OE vw cv joint are plenty strong and long lived,  if you really needed to you can use larger ones but 100mm joints can handel a 300 bhp 20vt without problems
some of the pattern joints are crap tho
all the VW's have gone bar 1.
Offline gizago
Re: CV joints
« Reply #5 on: 20 January 2012, 20:08 »
Fair enough, I dont know whats fitted, genuine or pattern, but I'll have a good look over the weekend.
