Author Topic: Paint problem and help :)  (Read 1191 times)
Offline Nebbo
« on: 16 May 2005, 17:43 »
Right to start off what colour is my car, J REG - its a blue sort of colour am i right in saying royal blue?? I have looked everywhere in the boot for the sticker to tell me and it just dont excist so could you clear this up for me....see below
Next problem i have a few rust bubbles dotted around the car and i was wondering if somebody could give me an extensive guide on how to get rid of them as i want to give it a go myself.  So give as much info as possible  :grin: NOOB alert!!
Would love any full on replies  :wink:
Ben
Offline Mart8V
  • I really should know better by now.....
Re: Paint problem and help :)
« Reply #1 on: 16 May 2005, 19:22 »
Hi.  No sticker at the back could indicate that it's had a rear-ender and respray. Any other evidence?
As for the rust spots, sand them off back to the metal, and mask up around the area.  In light coats, gradually build up the primer and allow to dry fully.  Then, rub down with some fine grade wet and dry paper, and clean to get rid of any dust.  As for the top coat, once again build up in light layers, and be very patient!  Best done out of breeze and direct sunlight.  Once complete, rub down again gently with damp wet and dry paper, and leave to harden before polishing.
That's the rough guide- I'm no expert!  Lots of the guys on here will be able to fill you in on the finer detail.
Good luck!
Offline TIM20
« Reply #2 on: 16 May 2005, 20:13 »
I have a royal blue golf. If i were you i would leave it to the experts.  The colour is really hard to blend in, you will always be able to see the repair if done with cans especially when its polished up.
Try to get a good quote with you doing all of the prep work, the time consuming but
Tim
Offline Deefadog
  • Mk2 16V (November 89)
« Reply #3 on: 16 May 2005, 23:04 »
LA5U - paint code if it's Royal metalic blue, looks like it.  see my sig mine is Royal metalic blue.
Good luck
