Author Topic: teledials on mk2  (Read 1870 times)
Offline dubpirate
teledials on mk2
« on: 17 January 2012, 18:59 »
hi guys i currently have a mk3 golf
on coilovers
with 15" teledials with 195 50 15s on and 20mm adaptors
can i put this streight on the mk3 i might buy
cheers dan
is tyre size and adapters ok
Offline dan_apps
  • too low for british roads!
Re: teledials on mk2
« Reply #1 on: 17 January 2012, 19:30 »
presume you mean mk2 you might buy? only if you have 4 x 100 vw fit adapters on the mk3.
Offline dubpirate
« Reply #2 on: 17 January 2012, 19:31 »
yes pal im buying a mk2
currently have a mk3 with 4 stud
is the 20mm adapters ok ?? and tyres
Offline dan_apps
« Reply #3 on: 17 January 2012, 19:34 »
cant seeing you having issues, adapter wise is dependant on how low you going and how much you want them to 'stick out' :smiley:
« Reply #4 on: 17 January 2012, 20:50 »
Just check the offset to be sure but mose teledials are around et53 so they will be fine on a mk3. :smiley:
Offline dubpirate
« Reply #5 on: 17 January 2012, 20:53 »
there currently on my mk3, im getting a mk2
« Reply #6 on: 17 January 2012, 23:57 »
Should be fine then :afro:
