Author Topic: Revo Stage 1 vs. Stage 2  (Read 10433 times)
Offline DubaiGTI
« on: 17 January 2012, 16:05 »
Hello All,
Having just passed the 15,000km mark since new, my bond with the little GTI grows stronger and stronger.
A few months ago I had the Revo Stage 1 upgrade which made a big difference to overall performance.  Now I'm yearning for more power and considering jumping to Stage 2.
Is there a big difference in performance between Stage 1 vs. Stage 2?
How will this play on warranty?  Flashing back to original from stage 1 is a simple procedure, 2 should be more complex?  (I have more than 2 years warranty left on the car).
Look forward to your comments.
Offline mkviken
Re: Revo Stage 1 vs. Stage 2
« Reply #1 on: 17 January 2012, 16:25 »
i had a look into this and the stage 2 map isn't any different to stage 1 on the mk6 GTI, apart from it doesn't give an emissions warning light when you fit a down pipe and de-cat or sport cat.
i was advised i could fit a decat or sport cat down pipe and run a stage 1 map and the only difference would be i may get the emissions light up a couple of times.
Golf GTI 7.5 230 white silver
Offline jdjd
« Reply #2 on: 17 January 2012, 16:33 »
Stage 2 gives alot more midrange shove.
 And to some it up, Stage 2 would come past a stage 1 in exactly the same manor as a as your stage 1 would over a standard GTI,
 Considerably faster and well worth the money
« Reply #3 on: 17 January 2012, 16:39 »
Big intercooler is bound to make a difference in the heat out there, what's the emissions regs out there? Could you run with a de-cat? That, with an intake and intercooler plus stg2 is going to be seriously quick.
Offline PenguinGTI
« Reply #4 on: 17 January 2012, 17:57 »
It depends on what you consider stage 2 to be.
If you are talking about upgrading the exhaust and the air intake then you're looking at a bit more power but not that much.
This is a bit exaggerated. An exhaust system will give an increase of about 15hp tops and a good intake will realistically give about 7hp. That adds up to 22hp theoretically speaking over a standard car. A remap alone can push an extra 50hp out of an otherwise stock motor.
Realistically, a good stage 1 map will give you around 260-270hp. If you add on the exhaust and intake upgrades then around 290 is to be expected. In fact I think KennyGTI on here got results around this figure on his stage 2. I can't remember if he was with Revo at the time.
If you are including a FMIC into the mix then you will get more consistent power but not necessarily more.
Have a look at this video http://www.youtube.com/watch?v=N715_Ux2Nao
The Stage 2 is marginally quicker but, IMO, in terms of sheer performance it's not quite the bang for buck of just going stage 1. Although it does alter the sound so for some that's an added factor.
Offline PenguinGTI
« Reply #5 on: 17 January 2012, 17:59 »
Also forgot to add, warranty wise it's the same case as going stage 1 in the first place. If you have a garage that's going to kick up a fuss about a remap then walking in with a modified exhaust and air intake is not going to go down well. If your dealer doesn't mind about a remap then they likely won't be too bothered about an upgraded exhaust or intake either.
And if you're wondering about taking the exhaust on and off every time your car goes in... well I wouldn't bother really. For the hassle stage 1 is fast enough.
Offline jdjd
« Reply #6 on: 17 January 2012, 18:41 »
Not sure your setup, But I was running straight though exhaust with decat, Intake with cold air vent leading straight to the intake, THS revo edition Intercooler, std fuel pump plugs etc... And my car would have absolutely thrashed the pants of a Stage 1 remap'd GTI.
 This is fact mate.....
 Also: that video isn't really stage 2, No intercooler and only a downpipe running minimum settings possible for stage 2,
« Last Edit: 17 January 2012, 18:47 by jdjd »
Offline KennyGTI
« Reply #7 on: 17 January 2012, 18:49 »
He stage two, you completely notice the difference! Much strong through the mid range right to the red line. I'll have a look for my rolling roads results of stage 1 vs stage 2 with same hardware mods, carbonio intake, blueflame turbo back exhaust and forge twintercooler.
APR Stage 2+
Offline KennyGTI
« Reply #8 on: 17 January 2012, 19:02 »
Stage one was 283bhp and stage two made 298 bhp. Biggest gap between the two was at 4000 revs was about 28bhp.
APR Stage 2+
Offline jdjd
« Reply #9 on: 17 January 2012, 19:03 »
Stage 2 isn't about BHP with Stage 2 comes all the torque stage 1 lacked :) Bet if you had the dyno the gap would be big
