Author Topic: Turbo/boost problem....still  (Read 7427 times)
Re: Turbo/boost problem....still
« Reply #20 on: 18 January 2012, 00:16 »
Any tips On buyin a vagcom lead?
I have and can recommend one of these http://www.ebay.co.uk/itm/VAG-Car-Diagnostic-Scanner-Fault-Code-reader-/160717750851?pt=UK_Diagnostic_Tools_Equipment&hash=item256b864243
Is that just a engine code reader then? Or can you do other stuff?
Also does ABS, Airbags/srs and gearboxes, mine has been a great purchase, I have helped lots of people out with it.
Offline golfyste
  • Project track car
« Reply #21 on: 18 January 2012, 00:19 »
Well I have a engine code reader bit it only comes up with the sai and when I clear it the light goes out, I just though vagcom would be good as you can do other things with it can't you?
« Reply #22 on: 18 January 2012, 00:21 »
Yes lots more  :smiley:
Offline golfyste
  • Project track car
« Reply #23 on: 18 January 2012, 00:23 »
But not with that you posted a link to?
Is it best to get a lead and disk?
« Reply #24 on: 18 January 2012, 00:25 »
Vagcom will do more than the ebay reader but it does enough, however vagcom is handy for logging problems etc.
Offline golfyste
  • Project track car
« Reply #25 on: 18 January 2012, 00:30 »
Ok cool, may look at gettin a lead and disc, then I gotta learn how to use it  :laugh:
What the min I'm gonna pay for a lead just don't wanna get a crappy Chinese one ha
Cheers mate
Offline golfyste
  • Project track car
« Reply #26 on: 18 January 2012, 17:00 »
so im gonna order a ebay lead and driver disc, i dont go home untill the 27th so will have to wait until then to do the logs,
so what are we thinking it could be?
the sai leaking?
a resistor missing somewhere?
something electrically limiting it? - what could cause this?
cheers for any help.
Offline golfyste
  • Project track car
« Reply #27 on: 19 January 2012, 22:25 »
Bump.
Offline golfyste
  • Project track car
Re: Turbo/boost problem....still / update
« Reply #28 on: 28 January 2012, 21:12 »
Sooo ... Home for the weekend and my vagcom eBay cable and disc had arrived so I set about scanning the car and found these codes ....
17705 - p1297 pressure drop between turbo and throttle valve
16795 - p0411 which I found is the secondary air injection
17704 - p1296 which I beleive is coolant mapping?
I did some research and found my n249 bypass needed a resistor so I have cleared the codes and put it in but any idea how to solve the other issues?
I also read the sai plug needs a resistor so will get one and do that tomorrow.
And idea how I could solve the coolant mapping problem or diagnose it as I can do measuring blocks now  :smiley:
Also got a big delivery from the postman including this intercooler :) so may do thr tommorrow.
Offline Chris.
« Reply #29 on: 28 January 2012, 22:00 »
Have you cleared them and ran the car before scanning?
Click For Build Thread
