Author Topic: positive camber on the front :S  (Read 4630 times)
Offline andynorfolk
  • if at first you don't succeed, get a bigger hammer
« on: 16 January 2012, 21:42 »
ever since lowering my car on coilovers the fronts have had positive camber while the rear has had a bit of negative camber...
i can't for the life of me work out why the fronts have positive camber after lowering... any help much appreciated :D :smiley:
Offline benvictors
  • bgk Tuning - coming soon!!!
Re: positive camber on the front :S
« Reply #1 on: 16 January 2012, 21:47 »
You can adjust the camber on the front with the two bolts that hold the strut to the hub, jack it up. take ya wheel off, loosen the bottom bolt slightly and the top bolt more, you can then pivot the hub slightly to adjust the camber  :wink:
VeeDubGTI16v
« Reply #2 on: 16 January 2012, 21:48 »
mcpherson strut suspension adds positive camber as the wheel rises basically
Offline andynorfolk
« Reply #3 on: 16 January 2012, 21:50 »
how much camber can you actually get from just adjusting the the strut bolts then?
Offline benvictors
« Reply #4 on: 16 January 2012, 21:51 »
Think its about 3-4 degrees each way from memory
Offline DOA
« Reply #5 on: 16 January 2012, 21:52 »
Depends where in the stroke you are and the specific geometry but typically struts do not add positive camber on bump travel  :rolleyes:. Perhaps your confusing bump with roll......
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #6 on: 16 January 2012, 22:11 »
Can of worms now officially open!
Thom
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #7 on: 16 January 2012, 23:35 »
On a mk4 are there 4 bolts, underneath the hub, that bolt it to the wishbone right?
Offline Diamond Hell
  • Opinions я Us
« Reply #8 on: 17 January 2012, 02:01 »
This, but unless you understand how to set up geometry and have either a set of gauges, or know how to accurately set up your front suspension manually, take it to a Protyre branch or similar and get them to set it up.
Ten quid says you've done the idiotic thing of bolting up coilovers and not taking it to a garage to get it set up.  Check your tyres for uneven wear.  I'll wager whatever turd you've nailed the coilovers to pulls to one side or the other under acceleration.  :grin:
Get it set up properly.  It will make a massive difference and will stop your car eating tyres. For road use I'd recommend -0.5 - -1 degrees of negative camber, which will sharpen turn in and improve in-corner grip.
Offline mcgee9t2
« Reply #9 on: 17 January 2012, 12:49 »
by "set up" do you just mean have the tracking ect checked/ adjusted?
just fitted my coilovers and was going to get the tracking checked out this weekend but is there more that needs to be checked out?
