Author Topic: electrical problem need help  (Read 1231 times)
Offline GTIcheeseman
« on: 16 January 2012, 18:13 »
Electrical situation it's had new alternator, new belt, new tensioner and new battery , new fuses above battery , checked all earths, checked connections above battery but every now and again I get all the electrics go off.
The engine nearly stalls and on and the abs light comes on saying alternator workshop. and this morning I done my windows up and it through the car into the same thing. .... I have a vag scanner and it did come up with 00668 battery supply terminal 30 ..........
 I really need help getting slightly annoyed....
Right new update today it's throwing up the abs /alternator lights but it's not killing the engine, I turned it off a second ago and from the dash or more under the dash there was clicking like a relay:/ now I don't see a relay being that loud but the millage clocks flickered as well also the wipers are now dead slow..... the rear n/s light has a has some dodgy wiring so dont know if that might be contributing.....
also now i can tell its gonna play up as my interior light flickers and i get a high pitch noise coming from the speakers when the stereos on ...... Really need help :( it might be good bye golf soon
« Last Edit: 16 January 2012, 18:22 by richw911 »
Offline richw911
Re: electrical problem need help
« Reply #2 on: 16 January 2012, 18:29 »
thanks maybe its best to a new holder cheers
Offline richw911
« Reply #3 on: 16 January 2012, 18:38 »
Remove it and check it - if it has signs of melting get it changed - also check the alternator is putting out the correct voltage and is not over charging  :smiley:
« Reply #4 on: 17 January 2012, 08:52 »
Well when I checked the battery when the engine was running, it was at 13.8
Offline richw911
« Reply #5 on: 17 January 2012, 10:58 »
Thats about right  :smiley:
« Reply #6 on: 17 January 2012, 23:00 »
Good lol is there any common electrical faults on the mk4 golf?
« Reply #7 on: 28 January 2012, 12:49 »
cleaned the fuse holder before a bought one and its spotless . cleaned both terminals, both earths and power cable to starter motor and its still doing  the same problem
