Author Topic: How-To - Remove Rear Bumper  (Read 11027 times)
Offline Steve_PD
« on: 14 January 2012, 13:24 »
Tools:
T25 Torx bit
T30 Torx bit
Ratchet
Parallel punch
hammer
1. Remove the rear lights (see guide).
2. Un-plug the rear number plate lights and push the grommet out. Below the passenger side light loom.
3. Remove 3 T25 bolts from each side wheel arch. (If your lowered you may need to jack the rear of the car up to remove the arch lining bolts.)
4. Remove 3 T30 bolts from the underside of the valance.
5. Remove the 2 T30 bolts from where the lights sit.
Red arrow is the T30 bolt and the Blue arrow is the locating rivet
6. Using a punch knock out the center of the locating rivet (see pictures)
Close up of rivet
7. Use a screw driver to pop the rivet out the hole.
8. Then pull on side out from the wheel arch, followed by the other side and the bumper should pop off.
Bumper off
If you got a sun roof its worth milking the drainage nipples on either side
Nipple
What comes out
9. Re-fit is the reversal of the above, but remember to push the number plate wiring through the hole first.
