Author Topic: What would I need?  (Read 1875 times)
Offline murraymint
What would I need?
« on: 13 January 2012, 22:41 »
What would I need to put a 2ltr abf in a 1.8 Jetta?
I mean like ecu, new loom etc?
josh
Offline X4MGS
  • VAG Parts SNOB!!!
Re: What would I need?
« Reply #1 on: 14 January 2012, 01:24 »
Do you mean the 1.8 Jetta that you were asking about a gearbox for?
Which has a Piersberg Carb set up??
I would hazard a guess at a 16V engine loom with ECU & ISV and 244 relay unit...
Rear of the loom you wouldn't need if its a CE2 (column mounted hazard switch)...
BUT I am only guessing and stand to be corrected by more knowledgeable people on here... RJ is the person to ask IMO
For More Info Click To See;
Offline murraymint
« Reply #2 on: 14 January 2012, 11:37 »
Yes that one but I don't know much at all about coz its my dads atm,
He's looking to sell it so I thort of buying it and if I've gotta taking the engine out to fit a new gearbox I maybe as well drop a new engine in there, so just seeing how much stuff I'd need to change on the car to suit an abf
josh
Offline murraymint
« Reply #3 on: 14 January 2012, 11:56 »
The hazard switch is on the steering collom btw
josh
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #4 on: 15 January 2012, 17:58 »
CE2
Offline rob.043
« Reply #5 on: 16 January 2012, 12:26 »
have a search and look through old posts in the relevant classifieds section. Infact, I think threre is a list in the maintinance section of parts required, by dannyp. Lots of info on here....
Anyway, it may be best to buy a mk3 16v as a complete car, and then you should have everything required. It has the potential to be cost effective if you break/scrap/sell the leftovers.
Offline DOA
« Reply #6 on: 16 January 2012, 18:41 »
You will also need a mk2 digi fuel tank, pump and lines if its carb fed at the moment and either convert to hydraulic clutch and cable gearchange or find a mk2 gti gearbox, flywheel and clutch that you are confident is in good condition.. Cheap mk3 donors are surprisingly common if your happy to wait a week or two.
