Author Topic: Official MTB thread  (Read 196922 times)
Offline murraymint
Re: Official MTB thread
« Reply #630 on: 28 June 2012, 16:48 »
Must of been hard going on that..... It's only got v brakes  :laugh:
josh
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #631 on: 29 June 2012, 00:25 »
I think braking was the least of his worries tbh!  :laugh:
Offline murraymint
josh
Offline T_J_G
« Reply #633 on: 01 July 2012, 18:00 »
Right got a problem with my cheapo halfords bike. The handle bars can be twisted out of alignment without much force. Making it unridable. I've tightened the allen key on the bit that hold the handle bars in but no luck. Any idea which bit needs replacing?
Offline rob.043
« Reply #634 on: 01 July 2012, 19:11 »
The halfords bike bit.
Is it just one bolt on top of the stem? If so, loosen it and remove the stem and bars, you will see the angled bolt that when tightened forms an interference fit into the tube, and holds it in place. Clean off any grease, and refit. Needs to be quite tight, usually with a 6mm allen key. If that isnt sufficient, strip again and roughen up the bolt etc with a file perhaps.
Offline T_J_G
« Reply #635 on: 01 July 2012, 19:42 »
Yup just one bolt on the stem, I'll remove it all again at one point but I did take t out and refit a week ago. Would it need replacing?
Offline rob.043
« Reply #636 on: 02 July 2012, 09:56 »
It wouldnt be too expensive to replace it, but it shouldnt really need to be replaced, its not a wearing part. You do have the angled face of the 'nut' mated to the angled face at the bottom of the stem, so that both will slide on tightening to push out and hold the steerer tube in place? If you put the nut on the wrong way round, it may not work?
Usually if its moving, its because the allen bolt is not tight enough. I would expect to put a bit of effort into tightening it with a 6 inch long allen key. With a tool any shorter you need to grunt to get it tight enough.
If you have no joy it may be time to take it down to your local bike shop. Hopefully if you get them at a quiet spell, someone can have a quick look and sort it out, if its a simple fix. The older the bike shop, the better, as they may well have spare bits lying around....
Offline Toby
  • Car - less
« Reply #637 on: 04 July 2012, 12:51 »
Going to look at a ' cube ' hard tail tonight.
Any good?!
Currently down under
Offline Toby
  • Car - less
« Reply #638 on: 04 July 2012, 19:55 »
New toy
What clothing do people wear :/
Any forums/ websites to buy new bits?
« Last Edit: 04 July 2012, 20:47 by Toby »
Offline brett
« Reply #639 on: 04 July 2012, 20:57 »
very nice mate  :cool:
