Author Topic: LED Number Plate bulbs  (Read 17086 times)
Offline p3eps
« on: 11 January 2012, 18:06 »
I'm sure I read something about this a couple of months ago - but the search came back with nothing.
Anyway... for the last 18months+ I've had a set of LED numberplate bulbs fitted - which emit nice white crisp light.  It's great for the RVC as it lights up the road behind you!
They were bought from eBay Hong Kong or similar, and cost about £30 for the pair.  The were the usual bulb holder filled with about 18 SMD LED's and then a small adapter box which tricked the MFD into not giving an error.
No problems apart from the occasional MFD warning if my lights went on, off and back on again during a journey - I would get the warning light on the dash.  When I switched the ignition off and on again, the warning would vanish for another few months!
Today I was driving to work and the warning came on.  A bit odd as it was dark and my lights had been on the whole time.  When I got to work, I looked at the lights - and one was flickering.  I meant to go out and look once it got light, but totally forgot until I got in the car to drive home again... in the dark.
When I got home, I put on my head torch, and pinged the bulb holder out.  One of the 18 LED's was on, and the others were all flickering.  I fiddled with it for a few minutes, but since it was dark and freezing, I removed the pair of them and put the originals back in.... which look really orange and dull now!
So... I want another set of LED bulbs.  I've found more on eBay - which look much like the ones I've just taken out.  My box (which I kept the originals in) said "Racing Dash" on it, and I think the eBay ones for about £30 again are the same thing.
I'm sure I read something about OEM LED bulbs a while back though.  Are there better ones out there than the ones I had?  Are they a stright swap?  Where can I get them?!
Golf R... 3 door, DSG, Leather, Reflex Silver, Black 19" Talladega Wheels, ACC, Parking Sensors, RNS510 with Dynaudio, Reverse Camera, Luxury Pack, Cruise Control & Fiscon Bluetooth.
Offline dieseldunc
Re: LED Number Plate bulbs
« Reply #1 on: 11 January 2012, 18:30 »
Here's one source for the original ones; you may want to just take the part number frmo the pic though and see if local dearler is competetive on price?
http://shop.ahw-shop.de/vw-golf-6-5k/beleuchtung-und-lichtanlage/blinker-und-kennzeichenleuchten/led-kennzeichenleuchte-golf-6-passat-polo..?c=1770
sssh; it's 'only a diesel'; but i love it!
MK6 GT140 TDi; DBP; Vancouvers; RNS510-D; Convenience pack; Storage pack; Philips Extreme Vision dipped bulbs; blue vision sidelights; red footwell lights; Yeti tips; GTD pedals; GTD gear lever; 'R' mats; RVC; Premium Bluetooth and some TLC.
Offline p3eps
« Reply #2 on: 11 January 2012, 19:12 »
Thanks...
I see the connectors look the same as the ones on my car already - but do they work straight out of the box - or need some jiggery pokery?!
Offline Jimble
« Reply #3 on: 11 January 2012, 21:01 »
If you fit the OEM ones that are fitted to later GTI's/R's you'll need something like these.
http://www.kufatec.co.uk/shop/product_info.php/info/p9003_c325_Adapter-LED-number-plate-light---VW.html
 :wink:
Offline AndyG
« Reply #4 on: 11 January 2012, 21:28 »
I own a mk6 gti,dsg front fairy led and rear led but wanted led number plate lamps.I ended up getting  some from convert2xeon and cost£36.The good thing is you get a resistor module with them so no faults.They been in since August and finish off the rear lighting a treat.
Golf 7R,DSG,5 door White,leather,rear camera.
Offline JamesR27
Mk 8.5 Clubsport Pure White, Queenstown, DCC.
MK 7.5 R Pure White, Pretoria Silver, DCC, Rear Camera.
Gone - MK 7 GTI Carbon Grey, Rear Camera, Service Pack.
Gone - MK 6 GTI  Reflex Silver, Monza Shadows, RCD 510, Rear Camera, Bluetooth, Tyre Pressure Sensor, Xenons Convenience pack, Service Pack :)
Gone - MK 5 GTI Reflex Silver, Monza II 18's, Luxury Pack, Mulitchanger
Offline AndyG
« Reply #6 on: 11 January 2012, 22:54 »
Mate,they look identical to the ones I got from convert2xeon except they are £10 cheaper.I can only say where I got mine from are a reputable company and for the extra £10 they cost,they do work and can be fitted by a novice like me in no time.
Offline p3eps
« Reply #7 on: 12 January 2012, 07:14 »
Thanks for the replies...
The OEM ones price is a bit off-putting if I need the Kufatec adapters as well as the £25 each bulbs.
The ones from convert2xenon look to be the same or similar to the ones I already have - which also look much the same as the eBay ones.
I guess it'll just have to be another set of them.  At least I have a spare incase of another failure!
Offline JoeGTI
« Reply #8 on: 12 January 2012, 12:43 »
I have the OEM ones along with the Kufatec adapters as linked to above. Fitted them about 3 months ago and they've worked perfectly. No dash bulb-out errors.
They weren't cheap, when you factor in the adapters, but they work!
Offline hatchfanatic06
  • I'll get it right eventually.....
« Reply #9 on: 12 January 2012, 13:09 »
They are a US based company so you might pay more on shipping but these are the best I have ever heard, and are recommended by many people who have them:
http://www.ecstuning.com/Volkswagen-Golf_VI--2.0T/Lighting/View_All/ES2093774/
Complete plug and play, the part number is the same for the MK6 GTI/Golf 2.5/TDI. Just checked the shipping, and it is kind of steep. For me atleast 73 pounds shipped. Might be able to take the MFG # and run an inquiry on ebay.co.uk and see what you come up with. Just wanted to recommend something that I know works and is reliable.
APR Stg 2 // APR TBE // APR Stg 1 Carbonio CAI // KONI Coil-Overs
My Build Thread
