Author Topic: another vauxhall help please  (Read 4207 times)
Offline SoundillusioN
Re: another vauxhall help please
« Reply #20 on: 10 January 2012, 14:31 »
My advice is to not waste any more time thinking about it and just drain the entire system and fill it back up with fresh water and antifreeze, it's easy enough.
It's a Vauxhall, nothing is easy  :laugh: Seriously, you've got to get the alternator out of a Zafira from underneath which costs a lot in labor  :lipsrsealed:
Yeah but it's bubbly coolant, working with water can't be much harder on a Vauxhall than any other car.  :wink:
Offline leeroy20vt
  • h reg mk2 gti
« Reply #21 on: 10 January 2012, 17:53 »
Yep i will drain it and flush again.with hose like did lastnight and try that
Offline leeroy20vt
  • h reg mk2 gti
« Reply #22 on: 15 January 2012, 14:43 »
drained flushed again pressure tested and all seemed ok  :undecided:
so i dunno im lost did find a tiny leak and i mean tiny sorted that then tested again all good lost no pressure
but for what ever reason its still full off bubbles
mayby time to give it to vauxhall  :cry: :cry:
Offline Bellend
« Reply #23 on: 15 January 2012, 14:44 »
Have you tried just plain water?
Where all my moneys went.
Offline leeroy20vt
  • h reg mk2 gti
« Reply #24 on: 15 January 2012, 14:51 »
yep i have indeed
im wondering if it has mayby had a turd block init at some point to stop a leak and its now reacting of something thats the only thing i can think of
Offline Bellend
« Reply #25 on: 15 January 2012, 14:53 »
yep i have indeed
Either that or a headgasket mate. Or crack somewhere.
Get it sniff tested.
Offline leeroy20vt
  • h reg mk2 gti
« Reply #26 on: 15 January 2012, 14:56 »
surely if it was head gaskest it would of showed up on pressure test ?
Offline Bellend
« Reply #27 on: 15 January 2012, 14:58 »
Not always. As I said a sniffer test will confirm if there is engine fumes in there. It looks like it to me.
Offline leeroy20vt
  • h reg mk2 gti
« Reply #28 on: 15 January 2012, 15:00 »
ok will get that done next its a pita someone just hit my audi as well so need this while the audi is being repaired
Offline Bellend
« Reply #29 on: 15 January 2012, 15:00 »
Fun times.
Just nab a courtesy car for the Audi?
