Author Topic: What parts do I need ????  (Read 2885 times)
Offline Charlieessex
« on: 08 January 2012, 23:23 »
Right I'm looking for about 300 bhp to 330bhp out of my agu 1.8turbo golf and I'm just looking at the bits that I will need to do this:
So far I have a vr6 clutch set up
3inch turbo back exhaust with de cat
Cold air induction
I'm going to he purchasing
fmic
Audi tt 225 injectors with rail
Samco boost hose set
T4 rep turbo with exhaust manifold
Adjustable fuel pressure regalator
A remap by RTec the £390 one for bigger turbos
Is this all I need  If not please point me in the right direction
Offline dom
  • Back in a Mk4
Re: What parts do I need ????
« Reply #1 on: 09 January 2012, 06:26 »
Internals?
« Reply #2 on: 09 January 2012, 09:17 »
I head that the stock internals are good for 350 before they start to bend rods ????
Offline jonrandom
« Reply #3 on: 09 January 2012, 09:53 »
Yeah you would just about be alright but you would be running it at the limit so risky.
Would also need the vr6 maf housing, a 255lph fuel pump and some bigger brakes!
Offline Yohan
« Reply #4 on: 09 January 2012, 10:19 »
Torque kills rods not BHP.
I've seen rods bend at 285lb-ft whilst others seem to survive over 300lb-ft. A bit of a lottery.
If you are spending the money though I'd do the internals to be safe.
Offline Chris#101
« Reply #5 on: 09 January 2012, 12:18 »
dont understand how people can keep making the same statement "rods are good for 300bhp bla bla bla"
each individual set of rods are going to be different from wear etc no matter how many miles are on them!!
not a dig dude  :wink: for some reason that statement just pushes my buttons  :rolleyes:
but likes been said
*fuel pump
*new forged internals (personally)
3" maf
what cc are the 225 injectors?
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
« Reply #6 on: 09 January 2012, 13:40 »
Can I get away with putting a set of forged rods in it and new bottom end bearings and knife edge the crank ???
Offline littco
« Reply #7 on: 09 January 2012, 13:57 »
Just fittings rods and new bearings would be fine. No need to knife edge and it'll save you removing the crank.
TT injectors might get you to 300bhp but anything over you'll want 550's really. Will give you room to get upto 350bhpmif you ever decided.
Rods are being run on 300+ cars, but I've also rebuilt engines on a stage 1 260bhp that bent a rod. Really not worth the risk of running on stock, cos I guarantee one will bend when you least cpect it.
From experience just fit the rods......
