Author Topic: overfueling and cutting out  (Read 815 times)
Offline insane21
« on: 08 January 2012, 17:11 »
can anyone point me in the right direction please, my car is running rich and wants to cut out when the revs drop below 1000, on start up it stalls unless i hold it above 1000, its idle its slightly erratic,also i can feel a slight surge in all gears, its had new maf sens and lambda sens and i have cleaned the throttlebody! any ideas? thank you in advance  :evil:
Offline daz veedub
  • Operation 1.8t bolf
Re: overfueling and cutting out
« Reply #1 on: 08 January 2012, 17:21 »
fuel filter change   :undecided:
fuel pump on way out  :undecided:
Offline richw911
« Reply #2 on: 08 January 2012, 17:28 »
Fault codes?
Offline stevelfc
« Reply #3 on: 08 January 2012, 18:36 »
Temp sensor as that tells the car how hot or cold the car is and sorts the fueling out
Offline insane21
« Reply #4 on: 09 January 2012, 14:25 »
yep ordered temp sensor, will keep this updated, i can not put it on comp because it will not respond, i think its the old aftermarket head unit thing where i take it out to read the codes! im lazy so ill keep buying parts for now, i have almost a spare car by here  :laugh:
