Author Topic: Dipstick guide plastic fell into the tube..  (Read 1434 times)
Offline JimBR
« on: 07 January 2012, 23:07 »
Hi guys..
I was fitting a creation Motorsport lower breather hose this morning and accidentally snapped the dipstick tube in half. As I was getting the remaining bit off around where it attaches I'm sure a small piece of plastic 2/3mm square fell into the tube.
Do I need to now drop the sump? Or will it be okay just to drop the oil and change the filter?
I drove it for 25 minutes earlier and it was fine, surely the oil screener on the pick up pipe will filter it out? Shouldn't cause any damage hopefully?
It seems quite a common problem and pieces must fall in without people knowing when the top parts go brittle ect..
Can anyone put my mind at rest?
Cheers  :smiley:
« Last Edit: 07 January 2012, 23:16 by JimBR »
Offline topher
  • Administrator
  • fully functioning
Re: Dipstick guide plastic fell into the tube..
« Reply #1 on: 07 January 2012, 23:10 »
on it's own it wouldn't trouble the strainer in the oil pick up, but you've just added to what is already commonly known for clogging up. If you have the tools and enthusiasm to do it and it's not been done before, now might be a good time to drop the sump and clean the pick up pipe.
Offline JimBR
« Reply #2 on: 07 January 2012, 23:15 »
So you don't think it'll cause any damage?
I've heard it's not too much work to drop the sump but it's effort, the amount of jobs I've done on mine/other peoples cars recently are getting silly and I'm losing motivation. Plus I don't have a 5mm round head Allen key for the 2 gearbox side bolts and I'd need sealant and probably a pick up pipe too.
If there's a risk of low oil pressure I'll do it  :sad:
Offline JimBR
« Reply #3 on: 08 January 2012, 13:09 »
Anyone else done this?
Oil change/drop sump?  :sad:
Offline richw911
Offline km
« Reply #5 on: 08 January 2012, 21:58 »
i've done that, i left it. car still drives! not saying i recommend you to leave it though haha.
Offline JimBR
« Reply #6 on: 08 January 2012, 22:24 »
I drove mine too.
I might just change the oil, I've ordered a bottle. Don't fancy taking the sump off, the pick up pipe should catch it.
Offline james2
  • No scammers please.
« Reply #7 on: 08 January 2012, 22:41 »
I drove mine too.
dont worry about it.  :wink:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline cullygti
« Reply #8 on: 08 January 2012, 23:07 »
till it breaks  :grin: only messing mate
Offline JimBR
« Reply #9 on: 08 January 2012, 23:21 »
Haha!
Everytime I drive I'm waiting for the oil pressure light, everywhere I've read said it should be fine :) so fingers crossed. They crack that often it must happen a lot and people not even know.
