Author Topic: speedo  (Read 10703 times)
Offline terryuk
speedo
« on: 06 January 2012, 23:34 »
hi guys i have a golf tdi 2001 speedo without the lcd display telling me stuff can i fit a speedo with the lcd display ? and do i have to change much wireing ? many thanks
« Last Edit: 07 January 2012, 09:53 by richw911 »
Offline Steve_PD
Re: spedo
« Reply #1 on: 07 January 2012, 00:56 »
What do you dont have none like this?
Offline terryuk
Re: spedo
« Reply #2 on: 07 January 2012, 01:04 »
no my one does not have the little display at the bottom of the black rectangle
the one you have a pic of is the one i would like to fit
Offline Steve_PD
Re: spedo
« Reply #3 on: 07 January 2012, 01:12 »
bit more info on it
http://www.golfgtiforum.co.uk/index.php?topic=98752.0
clocks can be found on ebay, forums or breakers, anything from £20-£200 for the R32 clocks. Just got to make sure you get the right style of clocks either IMMO2 or IMMO3
Offline terryuk
Re: spedo
« Reply #4 on: 07 January 2012, 01:13 »
thanks i will have a look now
Offline Steve_PD
Re: spedo
« Reply #5 on: 07 January 2012, 01:27 »
You'll also need someone with vag-tacho to be able to fit
Offline xtetx
Re: speedo
« Reply #6 on: 07 January 2012, 10:48 »
I want to do this but just seem like a ball ache!
Offline chrisr103
Re: speedo
« Reply #7 on: 07 January 2012, 17:58 »
You get the clocks & I can fit & code them for you
<a href="http://giffgaff.com/orders/affiliate/chrisr45" target="_blank"><img src="http://giffgaff.com/banner/01_80x15.png" width="80" height="15" alt="Get a free giffgaff Sim" /></a>
Offline xtetx
Re: speedo
« Reply #8 on: 07 January 2012, 18:41 »
That would be awesome man. Do I just need the clock and new arm with computer controls on? I think mine is an immo2. I really want the outside temperature to work on the screen too, I've read I need the thermometer and some wiring?
Sorry to be a noob! Ha
Offline chrisr103
Re: speedo
« Reply #9 on: 07 January 2012, 19:29 »
You will need the multi function stalk & the temp sensor from behind the front lower passenger grill,
If yours is immo2 then you can get either immo2 or immo3 clocks for it (Immo3 VDO ones are better as they can have miles to empty activated)
