Author Topic: '04 plate clio  (Read 3022 times)
Offline scarr89
  • Mk4 Golf, DERV FTW!
'04 plate clio
« on: 06 January 2012, 19:51 »
A slight issue with the missus' Clio, apart from the fact that it's a Clio. You start it up and the lights seem to fade, come back to normal, perhaps a little flicker, fade then back to normal. It does this only on start up, ie once you've driven a mile or 2 is stops...Any rough ideas?
 :smiley:
Offline clancy
Re: '04 plate clio
« Reply #1 on: 06 January 2012, 19:53 »
sounds like battery might be dying
MK3 GTI 16v
Offline houston
Re: '04 plate clio
« Reply #2 on: 06 January 2012, 19:55 »
its a cheese eating surrender monkey
Offline justalex81
Re: '04 plate clio
« Reply #3 on: 06 January 2012, 22:25 »
prob battery. could be anything with that gutless sh1te engine
Offline Diamond Hell
  • Opinions я Us
Re: '04 plate clio
« Reply #4 on: 06 January 2012, 22:33 »
Burn it.
Problem solved.
Offline DCD
Re: '04 plate clio
« Reply #5 on: 06 January 2012, 22:39 »
take the battery to a local garage get em to check it for you, most will do it free of charge or drop em a tenner!
Offline justalex81
Re: '04 plate clio
« Reply #6 on: 06 January 2012, 22:41 »
halfrauds will do it for free
Offline scarr89
Re: '04 plate clio
« Reply #7 on: 06 January 2012, 23:08 »
Burn it.
Problem solved.
Trust me I have told her this many times before  :evil:
Thanks for the 'constructive' criticism guys... :tongue:
She has the MOT due on it a couple of weeks is this something that would cause a fail? I have a multimeter to test it...if I can find it  :angry:
Offline danny_p
Re: '04 plate clio
« Reply #8 on: 06 January 2012, 23:22 »
Burn it.
Problem solved.
no need,  its french with an electrical gremlin
it'll burn itself
all the VW's have gone bar 1.
Offline DCD
Re: '04 plate clio
« Reply #9 on: 06 January 2012, 23:26 »
Burn it.
Problem solved.
if the headlights are in anyway faulty, irrespective of whether the issue lies with the headlights or not, then yes you could have troubles through an MOT - Surely you have some £50 MOT testers round your way ?
