Author Topic: VR6 WARM START ISSUE CUTS OUT  (Read 5197 times)
Offline todd
Re: VR6 WARM START ISSUE CUTS OUT
« Reply #10 on: 08 January 2012, 15:52 »
Sounds like a crank sensor because it's not starting when hot will be on the front of the engine next to the gearbox bell housing
Offline francoisd2446
« Reply #11 on: 08 January 2012, 20:11 »
Changed the hall sender also still now joy, guessing by the sound of it the injector and fueling are out, either injector is gone or pump is gone......
BTW if disconnect battery for 30 mins will this just reset everything I guess.....running out of ideas now and patience...
« Reply #12 on: 08 January 2012, 20:42 »
Here is the noise I get from injectors...  http://youtu.be/h81ZziGgpOs
It sounds like air but could it be stuck open injector causing flooding and non start ?
« Reply #13 on: 13 January 2012, 09:28 »
Ok plan of attack;
1) Going to try the "dumb mode" on vag software to see if get coms
2) Going to pull out injectors prime and see what is going on
3) Going to test ohms on injectors using multimeter
4) Going to get to crank angle sensor and possibly replace
5)clean up throttle body
6) look to change the brown sensor on in thermostat housuing.
« Reply #14 on: 14 January 2012, 20:44 »
Ok looked at earths today fixed a couple of doggy ones, so did not get to check fuel injectors, again starts first time then refuses to start, vag com in dumb mode only finding abs,,,,,
?????   :cry:
Offline DubAndDubber
« Reply #15 on: 14 January 2012, 21:16 »
HAVE YOU CHANGED THE CRANK SENSOR YET!
Mk5 Golf Gti 06'
« Reply #16 on: 19 January 2012, 13:09 »
I will change the crank sensor but want to find out what that noise is coming from the injector......
Offline todd
« Reply #17 on: 19 January 2012, 19:03 »
Fit the crank sensor get it running then replace injector if necessary, or if your really worried do it the opposite way round. Simple
« Reply #18 on: 19 January 2012, 19:42 »
Thanks for all the comments just ordered new crank sensor.....keep you updated...
« Reply #19 on: 20 January 2012, 00:45 »
How many times have you cranked it over? It could be possible that youve knackered your ECU.
Mk5 Golf Gti 06'
