Author Topic: Rear window de-mister  (Read 1814 times)
Offline walchy01
« on: 05 January 2012, 09:30 »
Mornig All
Although my rear window does eventually de mist when the switch is on, it is very very slow, am i right in thinking the only way to correct this is to replace the back window, my thinking is that the strips in the glass are damaged or not as good as they used to be :rolleyes: :rolleyes:
Thanks
Offline H Singh
Re: Rear window de-mister
« Reply #1 on: 05 January 2012, 09:48 »
Hi
You can get repair pens to relink the strips from ebay or halfords, try this it may help only a couple of quid.
Harry
Offline walchy01
« Reply #2 on: 05 January 2012, 09:57 »
Thanks will have a look..
Offline H Singh
« Reply #3 on: 05 January 2012, 09:58 »
It should work ive used it before on my wifes mk4
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #4 on: 05 January 2012, 11:35 »
If the circuit is broken in the glass, then It wont work at all.
Offline walchy01
« Reply #5 on: 05 January 2012, 16:01 »
That's my thought, only middle 3 lines seem to work :rolleyes:
Offline Santiago
« Reply #6 on: 05 January 2012, 19:19 »
Check the connections either side for corrosion, and clean as required. Will probably be green and very resistive if they've never been touched since Wolfsburg.  Be careful unplugging them though, may be a bit 'seized on'.
Any left-right elements that don't warm up after this, find and repair any breaks as above.
