Author Topic: Mk2 Alloy wheels  (Read 1984 times)
Offline RaulCarnahan
  • Raul
Mk2 Alloy wheels
« on: 04 January 2012, 10:00 »
Hi
I'm not sure if I can't search properly on the forum but I couldn't find any threads that will actually tell me what I need to know.
Only found some information on google and I am not sure if that is correct either.
So here goes;
What are the measurements for alloy wheel fitments for mk2?
The information I found on google says 4x100, ET35-42, centre bore 57.1
is this correct?
Also what is the optimum size for alloys? 15" Im guessing...
And the maximum size?
Thanks
Raul
Offline Mitching
Re: Mk2 Alloy wheels
« Reply #1 on: 04 January 2012, 13:12 »
Yes, you're right with the information you found.
As for wheel size, anything from 13"-17" will fit, dependant on the size of the brakes.
IIRC, I think the smallest an 8v gti can get is 14", they need about a 60 profile tyre, so they will look 'balloony'.
17s will look ridiculous.
I'd say 15s are best for a mk2, 16s can look really good too, take Mr. Blue's as an example  :smiley:
Offline Mr Blue
« Reply #2 on: 04 January 2012, 13:33 »
« Reply #3 on: 04 January 2012, 13:49 »
15" wih 195/50/15's is the best choice really.
Offline dubber36
« Reply #4 on: 04 January 2012, 13:55 »
Or 185-55-15's if you want to keep OEM.
  • Raul
« Reply #5 on: 04 January 2012, 15:39 »
Thanks for the replies, been very helpful.
What sort of rim width would best?
Raul
Offline Diamond Hell
  • Opinions я Us
« Reply #6 on: 04 January 2012, 23:01 »
Most choice and definitely the way to go.
I run Team Dynamics wheels as they're 6.6kg vs some of the VW OEM wheels, which are around 9kg.  :sick:
