Author Topic: massive overfueling issue  (Read 2594 times)
Offline mr mk2
« on: 03 January 2012, 23:28 »
hi has any1 come accross an overfueling problem that absolutly fills the combustion chamber on a 8v gti there for giving it a hydrolic lock and making it unable to turn over.
was thinking could b a problem with whateva it is that turns the fuel pump off when u first turn the ignition on but not sure what it is, any ideas?
Re: massive overfueling issue
« Reply #1 on: 03 January 2012, 23:44 »
Is it a Digi if so yes blown ecu caused by a failed / broken earth strap.
Offline AudiA8Quattro
« Reply #2 on: 04 January 2012, 19:36 »
+1 Injectors stick open.
Offline john64
« Reply #3 on: 04 January 2012, 21:19 »
if it's a Digi, check your fuel pressure regulator, mounted on the end of the fuel rail. If the diaphragm fails, return fuel redirects through the top port (vacuum line) to the throttle body, filling up the intake and cylinders.
John
1991 Golf GTI 8V
1992 Jetta 8V
Offline mr mk2
« Reply #4 on: 04 January 2012, 21:58 »
nice1 thanks for ur help
