Author Topic: help from Spain, 1.8t AGU (injectors and stage 2)  (Read 5961 times)
Offline CyRuS
« on: 03 January 2012, 00:56 »
hello, introduce myself, my name is Jorge and I write from Madrid (Spain). Currently, I have a 1.8t gti AGU 1999 and the car has a reprogramming stage 2.
changes
- Apexi intake or BMC CDA (which is better?)
- Fpr 4 bar
- Downpipe 2.5 "supersprint
- Cat back
- Fuel pump seat leon cupra r
- k03s
- revo stage 2
- forge 007p
- inlet pipe forge
- silicone hoses
I have at home also to mount an intercooler THS, and also a clutch lightened flywheel ECS.
The car works well but I have fear if the 286cc injectors are too small. I have read in this forum
you ride Saab red injectors and Maf 3 "of a golf VR6 (I have the injectors and maf but I have not yet installed)
I can install injectors SAAB RED and MAF 3" without changing the reprogramming?
The 286 injectors and fpr 4bar will be sufficient for the k03s?
I raise two logs of the car last week I have for you you see them
Forgive my bad English, and help me because in Spain there is not information about 1.8t AGU.
   Group A:   '002
      Idle speed   Engine load   Inj. period   Air mass in
   TIME   800-920 rpm   0.5-1.5 m/s   1.00-3.00 m/s   1.8-4 g/s
MARKER   STAMP    /min    ms    ms    g/s
   0.54   1320   1.85   4.93   7.57
   1.68   1360   4.55   9.41   20.34
   2.81   1560   5.35   10.37   27.01
   3.93   1840   6.35   13.31   37.36
   5.07   2120   8.65   16.32   58.33
   6.19   2440   12.75   16.32   99.86
   7.32   2880   12.75   16.32   117.71
   8.46   3400   12.75   16.32   138.75
   9.59   3880   12.70   16.32   157.36
   10.73   4320   11.55   16.32   160.00
   11.87   4760   11.25   16.32   171.11
   13.00   5160   10.75   16.32   177.92
   14.12   5480   10.15   16.32   176.59
   15.26   5760   9.85   16.32   181.25
   16.39   6040   8.75   16.32   168.47
   17.51   6280   8.45   16.32   169.23
   18.65   6480   8.35   16.32   171.73
Group A:   '014
   Engine speed   Engine load   Cyl 1 retard   Cyl 2 retard
TIME   0-6800 rpm   0-10 m/s   0-9 degCA   0-9 degCA
STAMP    /min    ms   °   °
0.37   1280   2.75   0.0   0.0
1.49   1400   4.55   0.0   0.0
2.64   1600   5.35   0.0   0.0
3.78   1880   6.35   0.0   0.0
4.91   2160   9.05   0.0   0.0
6.05   2480   12.75   0.0   2.2
7.17   2960   12.75   0.0   1.5
8.31   3440   12.75   2.2   1.5
9.46   3920   12.50   2.2   0.7
10.59   4360   11.80   1.5   0.0
11.71   4800   10.95   0.7   2.2
12.83   5200   10.30   0.0   1.5
14.00   5480   10.10   0.0   1.5
15.14   5800   9.10   3.0   0.7
16.30   6040   8.65   3.0   0.7
17.44   6280   8.45   1.5   0.0
Group B:   '015
   Engine speed   Engine load   Cyl 3 retard   Cyl 4 retard
STAMP    /min    ms   °   °
0.76   1320   3.65   0.0   0.0
1.87   1480   4.85   0.0   0.0
3.03   1680   5.65   0.0   0.0
4.16   1920   6.95   0.0   0.0
5.30   2240   10.50   0.0   0.0
6.42   2640   12.75   0.0   2.2
7.55   3120   12.75   0.0   0.0
8.69   3600   12.75   0.7   0.7
9.83   4120   12.20   0.0   2.2
10.96   4520   11.45   0.0   1.5
12.10   4920   10.70   2.2   0.7
13.20   5280   10.20   3.7   3.0
14.39   5600   10.05   3.7   3.0
15.52   5880   8.85   3.0   2.2
16.69   6160   8.60   2.2   1.5
17.81   6360   8.35   1.5   4.5
« Last Edit: 03 January 2012, 01:51 by CyRuS »
Offline james2
  • No scammers please.
Re: help from Spain, 1.8t AGU (injectors and stage 2)
« Reply #1 on: 03 January 2012, 01:04 »
Welcome. Nice choose of car, i have the same. Only advise i can give you, is use a airfilter set up as mine. Dont put it in wheel arce. I chopped it down so it sat next to battery and got new filter. I tryed them all / i love this one . :wink:
« Last Edit: 03 January 2012, 01:06 by james2 »
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline CyRuS
« Reply #2 on: 03 January 2012, 01:32 »
this is my 1.8t with Apexi
Offline james2
« Reply #3 on: 03 January 2012, 01:38 »
weres your n75. And remove the rubber off your ingition amp. Looks good.  :smug:
Offline CyRuS
« Reply #4 on: 04 January 2012, 00:47 »
Hello any opinion, someone with AGU and stage 2 with saab injectors and maf 3 "
I do not remove the rubber amp ignition in case I ever want to put original intake, the n75 is in its original place
Offline Dave_IOW
« Reply #5 on: 04 January 2012, 07:29 »
After putting vr6 maf on, you will need it reprogrammed yes. Think Calibre yellows are more suited to vr6 mad. Saab reds for 3'' I'D maf :wink:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline CyRuS
« Reply #6 on: 04 January 2012, 10:17 »
 yes, I have the red saab injectors 350cc, I had read that red saab injectors and vr6 maf can be placed without changing the reprogramming.
 as seen in the log, the inj. period is 16.4 maximum, this is not very high but I do not know very well interpret these values
Offline CyRuS
« Reply #7 on: 04 January 2012, 13:22 »
in this thread talking about my question, I understand that vr6 maf and injectors saab red is a good combination
http://www.golfgtiforum.co.uk/index.php?topic=195623.0
http://www.golfgtiforum.co.uk/index.php?topic=187178.0
