Author Topic: Winding in piston on rear caliper  (Read 3548 times)
Offline tobz.
« on: 13 May 2005, 12:55 »
I have a slightly sticking rear caliper on my golf which I may tackle tomorrow. When I've done this in the past I've not been able to push the piston back in and had real hassle re-assembling everything. Am I right in thinking the piston on rear caliper can't simply be pushed back into the caliper??? I remember hearing about a caliper winding tool available from halfords, does anybody know how this physically works???
Don't want to tackle the job again unless I have the rigght tools to hand.
Toby
You got any pics of your dad's split ?
Offline MK4_20VT
Re: Winding in piston on rear caliper
« Reply #1 on: 13 May 2005, 14:14 »
The caliper cannot be pushed back in, you do need to wind it in, with either the tool from Halfords or what I use a LARGE allen key  :smiley:
Offline KKK
« Reply #2 on: 13 May 2005, 14:14 »
Without the tool from Halfords, don't even attempt it.  Life is too short.
KKK
Offline tobz.
« Reply #3 on: 13 May 2005, 14:45 »
Found a few of these wind-back tools at online toolshops but I need one tomorrow (driving 200miles to somerset soon so gotta free it up before then) does anybody know how much the one is from halfords???
Had a look at the online bentley manual and you can use an allen key for pre-88 calipers but for later ones you have to use the special tool.
Judderi
« Reply #4 on: 13 May 2005, 17:00 »
Use the tool. It basicly pushes and turns at the same time. Not sure how much the halfords one is. I bought it last time i did the rears, it does not fit quite right as i think its designed for every make but vw but still does the job in the end. Worth buying for any future use.
Offline The Hoax
« Reply #5 on: 13 May 2005, 18:06 »
I just did this job the other day on my 1990 16 valve which does not have the allen key fitting type piston. I found it quite easy without any special tool, just a set of footprint grips. I did, however have to take the calipers right off the car as you have to press and turn at the same time and this was not possible with the calipers in place. It was a doddle to take the calipers off and a put them in my workmate bench and pressed the pistons in using a hammer shaft which I leaned on with my chest while turning the pistons with the grips.
« Last Edit: 13 May 2005, 18:09 by The Hoax »
Offline GTI EDITION (aka LTD)
« Reply #6 on: 13 May 2005, 18:35 »
One thing I would recommend when winding back the pistons is to spray a bit of WD40 / DUCK OIL around the rubber boot where it seats on the piston . this will stop it from getting twisted up and possibly splitting  :wink:
 P.S. WAS GOING TO MAKE  A COMMENT ABOUT" RUBBER THINGS SPLITTING WHEN BEING PUSHED IN " BUT THOUGHT BETTER OF IT " !  " DOH  " !!!! :grin:
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=topn&cat=19378
Does my arse look TOO BIG (to fit) in this (forum).... or was it something I said ?
Veedubgt18v
« Reply #7 on: 13 May 2005, 22:11 »
:grin: :grin: not what you want to happen.......:tongue:
Offline animaniac
« Reply #8 on: 14 May 2005, 05:08 »
on the vr6 it didnt have the allen key!! :evil: :evil: it had the daft 2 little bits!!
it says in the haynes use circlip pliers!! we tryed...... and failled!
so we got an old 15 socket i think it was some size... and we got the grinder on it and cut it away so it left 2 little spike things on either end...... and this fit just about in the daft piston things and wound it back in!!
you can buy a tool
but ours works on the same principle! :evil: just not as good.... but it did the job..
Offline Mart8V
  • I really should know better by now.....
« Reply #9 on: 14 May 2005, 08:55 »
Circlip pliers are a waste of time on these calipers, in my experience.  Spent hours trying to do it then gave up and paid the local place £15.  I was shame faced, but at least it got done!   :embarassed:
