Author Topic: What to look out for when buying a MK4? S TDi's  (Read 3719 times)
Offline Bellend
« on: 01 January 2012, 16:20 »
What engines are in these S TDIs?
Insurance is cheap on an S or an SE TDI, GT TDI or match TDI = ££££££.
Pretty much definately getting one. Going to have about £2k to spend on one but would push more if it's worth it. Currently got £1500 spare for a car and could push it round to have up to £4 but would rather save a bit more.
Plus will get a grand for a Micra I bought.
But yeah what to look out for and what sorta mileage is scary on these cars?
Thanks!
Where all my moneys went.
Offline richw911
Re: What to look out for when buying a MK4? S TDi's
« Reply #1 on: 01 January 2012, 16:43 »
From my limited knowledge the s are pretty flat and under powered but as you say cheap so ideal for what you need  :smiley:
Should be good for over 200k if serviced properly  :smiley:
Usual mk4 problems Plastic Window reg clips, Leaking rear washer, Worn axel  / front wishbone / dogbone bushes Faulty door modules to name a few  :smiley:
Offline Bellend
« Reply #2 on: 01 January 2012, 17:13 »
OK thanks.  :smiley:
Is it not the same engine? Although I've found SE 130 TDI 6 speed is pretty cheap to insure so wondering whether to go for an estate.  :smiley:
Do the later MK4's suffer from the same electrical/comfort control issues the older ones did?
Should be a pretty cheap reliable car that I won't fettle with too much. The lowered MK3 has it's place but on the motorway it's a b!tch.  :grin:
Offline Bellend
Offline Steve_PD
« Reply #4 on: 01 January 2012, 18:56 »
sdi :sick:
Slower than a snail
Offline Bellend
« Reply #5 on: 02 January 2012, 01:16 »
sdi :sick:
Slower than a snail
That's a 130 PD TDi. :)
