Author Topic: Decats?!  (Read 4059 times)
Offline Li-D
Decats?!
« on: 01 January 2012, 15:13 »
Thinking of decating the tdi, as in smash the innards out or replace it with a pipe but im nit clued up with the new mkt regulations coming into place.
Been told different thing like it doesnt need a cat due to no emmisions test just smoke test- true but ben told cat has to be present regardless whether smashed through or not.
But been told can pass without cat present too?!
Anyone know the real truth about turbo diesel mot bout exhaust, emmisions. Smoke test...
Mk3 Golf TDI - GTD replica in progress....
OEM CHIPPED....
NO POKE WITHOUT SMOKE!
Re: Decats?!
« Reply #1 on: 01 January 2012, 15:43 »
Will not matter on yours due to age, as long as it pases the smoke test you will be fine
Offline Li-D
Re: Decats?!
« Reply #2 on: 01 January 2012, 17:42 »
Is regarding taking innards out or decat pipe?
Could be getting it chipped too which will makr it smoke more!
« Last Edit: 01 January 2012, 17:54 by Li-D »
OEM CHIPPED....
Re: Decats?!
« Reply #3 on: 01 January 2012, 20:22 »
Decat pipe is a better option but knocking the insides out will be fine, yes a remap / chip will mean more smoke but it should still pass the mot.
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Decats?!
« Reply #4 on: 01 January 2012, 20:56 »
I have just bought a pipe like this, with the cat taken out but then welded back up. Now speaking to my mechanic mate he insists it will fail my MOT, begin of Feb, if I put it in.
But I want to put it in so I can get my custom map done in Jan!
He also said that diesels do still get emissions tested, and if its above X amount, I think he said 3 something, then it will fail!
Would a remap defo make it smoke more? If it makes it smoke more could I say use some Redex to help it pass the MOT?
Offline Li-D
Re: Decats?!
« Reply #5 on: 01 January 2012, 21:17 »
Might just take innards out of cat rather than risking decat pipe option, my bro in law is a tech at kwik fit will talj too him aswell
OEM CHIPPED....
Re: Decats?!
« Reply #6 on: 01 January 2012, 23:26 »
What year is your car, the op has a mk3 which would only get smoked tested, a newer car will be emissions tested.
Offline Li-D
Re: Decats?!
« Reply #7 on: 02 January 2012, 07:57 »
Its a 98 mk3 tdi golf 90bhp ahu if thats any help
OEM CHIPPED....
Re: Decats?!
« Reply #8 on: 02 January 2012, 20:31 »
You will be fine with your age of car.
Offline Li-D
Re: Decats?!
« Reply #9 on: 02 January 2012, 21:38 »
Ok what sort of difference would it make after chip?
OEM CHIPPED....
