Golf mk4
Wazzzer
sump change 20v ?
Topic: sump change 20v ? (Read 1119 times)
1toomanyuk
Here all the time
sump change 20v ?
01 January 2012, 09:51 »
anyone changed sump on there 20v is straight forward friend tells me i have to remove gearbox seems bit extreame any advice appreciated
marcos
Re: sump change 20v ?
01 January 2012, 09:54 »
You dont need to remove the gearbox hardest part is removing the bolts which are behind the flywheel, you will need ball end allen keys for them, i tryed for hours with wobble bars etc and just couldnt do it! Till a friend turned up with them and they came straight out
D4VEY01
1999 GTI 1.8T AGU BLACK
01 January 2012, 10:02 »
+1 ,as above ,i did mine not so long ago,but dont put to much sealant on, only a 3mm wide bead all the way round max and take ur time.
1999 : GTI : 1.8T : AGU : SPEC 1 R-TECH REMAP : BOSCH SUPER 4 : FORGE TIP : SILICONE TURBO HOSE KIT : 18" RS4 ALLOYS : -30MM ADJ SPAX SHOCKS/SPRINGS : FORGE 007P D/V (YELLOW) : MILLTEK CAT BACK RES 4MOTION : POWERFLEX DOG BONE BUSHES : PIPERCROSS FILTER : FORGE ACTUATOR (YELLOW) :
1toomanyuk
Here all the time
01 January 2012, 10:10 »
cheers thats what i thought box off seems nuts im gonna attempt today see if im on good form or not :
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
01 January 2012, 12:36 »
Will be getting mine done on this service
1999 1.8T: R-Tech remap - 225bhp/256lb/ft : K03s : THS FMIC : THS PCR pipe : 2.5" stainless exhaust : THS FR3 Engine mounts : G60/VR6 clutch : Calibra Yellow injectors : VR6 MAF : Devils Own WMI : Forge 007p : Carbonio CAI : Leon Cupra R Brembos : FK AK Street coilovers : Votex skirts : Anniversary front : click --->
http://www.golfgtiforum.co.uk/index.php?topic=92175
Golf mk4
Wazzzer
sump change 20v ?
