Author Topic: Starter motor **UPDATE*New picture*  (Read 2968 times)
Offline Dave_IOW
« on: 31 December 2011, 11:17 »
Went into Unipart to get myself a replacement starter to be told they are £75 upwards and it could be one of six variants (8 tooth, 9 tooth, 2kw... etc)
Any truth in this?
He had my reg and engine code so would have thought it would have been more accurate?
« Last Edit: 08 January 2012, 09:39 by Dave_IOW »
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Starter motor, 6 variants,.... really?
« Reply #1 on: 31 December 2011, 11:26 »
that's a bit bizarre... :huh:
Offline Dave_IOW
« Reply #2 on: 31 December 2011, 11:38 »
Indeed, just about to go up there and have a look, i'm kinda hoping its a wire that has fallen off  :rolleyes:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 31 December 2011, 11:50 »
you got a multimeter to test it? Try touching the switched wire direct to the battery and see if the solenoid kicks
Offline Dave_IOW
« Reply #4 on: 31 December 2011, 11:52 »
I haven't no  :sad:
Offline barrym381
« Reply #5 on: 31 December 2011, 13:49 »
I haven't no  :sad:
can u not get yours recond :smiley:
Offline Dave_IOW
« Reply #6 on: 31 December 2011, 14:29 »
Right update i have got it off to test it, wired up the casing to -VE and the power and switched to +VE and i get this?
Should it spin or what? It obviously works, but no spin?
When it was still in car i could not hear this 'click' of the shaft shooting out though?
Offline richw911
Re: Starter motors, is this right? *VIDEO INSIDE*
« Reply #7 on: 31 December 2011, 14:38 »
Burnt out i would say  :smiley:
Can you spin it by hand?
« Last Edit: 31 December 2011, 14:40 by richw911 »
Offline Dave_IOW
« Reply #8 on: 31 December 2011, 14:40 »
One way easily, though other is reasonably difficult but can be spun yes..  :huh:
« Last Edit: 31 December 2011, 14:44 by Dave_IOW »
Offline richw911
« Reply #9 on: 31 December 2011, 14:41 »
As per other post i would say it burnt out / has a burnt spot.
