Author Topic: Check my MAF graphs please  (Read 3807 times)
Offline mrapoc
« on: 30 December 2011, 00:39 »
Hello.
Been having some MPG issues and decided to test the MAF using blocks 3,8 and 11. I made some graphs where I start at 1.5k in 3rd and red line it. I repeat it a few times in the test. Lemme know what you think.
Thanks!
Offline mrapoc
Re: Check my MAF graphs please
« Reply #1 on: 30 December 2011, 12:17 »
Does the MAF readings look dodgy? If so i can go order one today.
thanks guys
Offline mrapoc
« Reply #2 on: 30 December 2011, 12:59 »
Also, do I see my turbo overboosting?
Offline javalin
« Reply #3 on: 03 January 2012, 08:36 »
its not how i'd usually expect to see them.  for an analog sensor (i.e. mk3) :-
http://www.picoauto.com/waveforms/Sensors/MAPSensor/wave127.html
how are you capturing the traces?
James
« Last Edit: 03 January 2012, 13:18 by javalin »
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline mrapoc
« Reply #4 on: 03 January 2012, 13:02 »
Hi.
Its a mk4 golf 115 gt tdi.
I captured it using vagcom measuring blocks 3, 8 and 11 going from 1000 to red line in 3rd. cheers
Offline mrapoc
« Reply #5 on: 03 January 2012, 13:03 »
I've logged another run in 4th from 30mph to redline. Ill stick that up shortly
Offline mrapoc
« Reply #6 on: 03 January 2012, 15:02 »
Code: [Select]
Group A: '003 Group B: '008 Group C: '011
Engine speed MAF (specified) MAF (actual) EGR duty cycle Engine speed IQ driver's req IQ via rpm(Torq) IQ via MAF Engine speed Spec. intake press. Actual intake press. D.cycle MAP
TIME 820-900 230-420 230-420 10-95% TIME 2850-3150 50-55 44-47 47-52 TIME 2850-3150 2000-2150 2000-2200 40-95%
Marker STAMP /min mg/str mg/str % STAMP /min mg/str mg/str mg/str STAMP /min mbar mbar %
1.15 1260 850 445.9 4.8 0.35 1281 36.8 42.8 17.8 0.75 1239 1683 1101.6 20.3
2.34 1323 850 490 4.8 1.55 1281 59.8 42.8 27.5 1.96 1302 1734 1275 19.9
3.54 1407 850 519.4 4.8 2.74 1344 59.8 43.4 29.1 3.14 1386 1815.6 1377 21.5
4.74 1491 850 578.2 4.8 3.94 1428 59.8 44.2 30.5 4.34 1470 1917.6 1519.8 23.5
5.94 1617 850 646.8 4.8 5.14 1533 59.8 45.6 34.6 5.54 1575 2040 1693.2 27.9
7.14 1764 850 769.3 4.8 6.34 1659 59.8 48.6 40.1 6.74 1701 2142 1938 43.8
8.34 1932 850 965.3 4.8 7.54 1827 59.6 50.8 48 7.94 1869 2142 2264.4 63.4
9.54 2121 850 1127 4.8 8.74 1995 58.2 50.2 54.1 9.14 2058 2142 2539.8 82.9
10.74 2310 850 931 4.8 9.93 2163 56.5 49.4 53.8 10.34 2226 2142 2478.6 90.4
11.94 2478 850 788.9 4.8 11.14 2373 55.2 48.9 49.7 11.54 2415 2142 2009.4 81.3
13.14 2625 850 774.2 4.8 12.34 2520 53.8 48 43.1 12.74 2562 2142 1907.4 72.9
14.34 2772 850 891.8 4.8 13.54 2667 52.7 47.2 45 13.94 2730 2142 2080.8 76.9
15.54 2919 850 926.1 4.8 14.74 2835 51.9 46.1 50 15.14 2877 2142 2193 80.5
16.74 3066 850 911.4 4.8 15.94 2982 50.8 45.6 48.9 16.34 3024 2142 2213.4 82.9
17.94 3192 850 931 4.8 17.14 3108 50 45.3 48.3 17.54 3150 2142 2254.2 87.7
19.14 3318 850 960.4 4.8 18.34 3234 48.9 45.3 48 18.73 3276 2142 2295 94
20.34 3423 850 945.7 4.8 19.54 3360 48 44.7 47.5 19.94 3402 2142 2295 94.4
21.54 3528 850 940.8 4.8 20.74 3465 47.2 44.2 46.9 21.14 3486 2142 2284.8 94.4
22.74 3612 850 916.3 4.8 21.93 3549 46.7 43.6 46.7 22.34 3591 2142 2274.6 94.4
23.94 3696 850 931 4.8 23.14 3633 46.1 43.1 46.7 23.54 3675 2142 2274.6 94.4
25.14 3759 850 931 4.8 24.34 3717 45.6 42.5 46.4 24.74 3738 2142 2264.4 94.4
26.34 3822 850 916.3 4.8 25.54 3780 45 42.3 46.4 25.94 3801 2142 2254.2 94.4
27.52 3885 850 911.4 4.8 26.74 3843 44.7 42.3 46.1 27.14 3864 2142 2264.4 94.4
28.74 3948 850 940.8 4.8 27.94 3906 44.2 42.5 46.1 28.34 3927 2142 2274.6 94.4
29.94 4011 850 931 4.8 29.14 3969 43.9 42.5 46.1 29.54 3990 2142 2284.8 94.4
31.14 4053 850 926.1 4.8 30.34 4032 43.4 42.8 45.8 30.74 4032 2142 2295 94.4
32.34 4116 850 906.5 4.8 31.54 4095 43.1 41.5 45.3 31.94 4095 2142 2284.8 94.4
33.54 4158 850 901.6 4.8 32.74 4137 42.8 40.6 45 33.14 4158 2142 2284.8 94.4
34.74 4200 850 911.4 4.8 33.94 4179 42.3 39.5 44.5 34.34 4200 2142 2284.8 94.4
35.94 4263 850 896.7 4.8 35.12 4221 42 38.4 43.9 35.52 4242 2142 2274.6 94.4
37.14 4284 850 862.4 4.8 36.32 4263 41.7 37.6 43.6 36.72 4284 2142 2264.4 94
38.34 4326 850 857.5 4.8 37.54 4305 41.5 37.1 43.1 37.94 4326 2142 2254.2 94.4
39.52 4368 850 837.9 4.8 38.74 4347 41.2 36.2 42.5 39.14 4347 2142 2244 94.4
40.72 4389 850 833 4.8 39.92 4389 40.9 35.7 42 40.32 4389 2142 2233.8 94.4
41.92 4431 850 828.1 4.8 41.12 4410 40.9 35.1 41.7 41.52 4410 2142 2223.6 94.4
43.19 4452 850 828.1 4.8 42.35 4431 40.6 34.3 41.2 42.77 4452 2142 2213.4 94
44.4 4473 850 813.4 4.8 43.6 4473 40.4 34 40.4 44 4473 2142 2203.2 94.4
45.6 4494 850 798.7 4.8 44.8 4494 40.4 33.5 40.1 45.2 4494 2142 2193 94.4
46.8 4536 850 808.5 4.8 46 4515 40.1 33.2 40.1 46.4 4515 2142 2182.8 94.4
Want a graph?
Offline javalin
« Reply #7 on: 03 January 2012, 15:16 »
please  :smiley:
Offline mrapoc
« Reply #8 on: 03 January 2012, 20:58 »
Checked out my MAF. Is it aftermarket? Its an SMP Europe MAF. Also the airbox...looks very different to my mate's. If so, I can go to TPS tomorrow and pick up the correct ones
Offline javalin
« Reply #9 on: 04 January 2012, 11:22 »
graph doesn't really mean a lot, for comparison I'd expect to see Throttle vs airflow type of thing.  Not much help - sorry
Airbox & maf look geninue, but I don't know the mk4.  Post it in the mk4 section - they'll probably know more.
James
