Author Topic: Vagcom results  (Read 6240 times)
Offline mrapoc
Vagcom results
« on: 29 December 2011, 17:28 »
Got my hands on the kit. Could someone have a quick look at results. Been having rubbish mpg! Testing blocks 3, 8 and 11.
I can provide the excel data if needed, but to make it nice - i've tried to make some graphs that may be useful. I don't really know what I'm looking for so I've used what I think might be useful.
edit: Graphs are in post below as these were not very useful
Temperatures after all the testing:
Fuel Temp   Fuel cooling state   Intake Air Temp   Coolant Temp
~Amb.Temp.°C   On:100%-Off:0%   ~Amb.Temp.°C   ~Amb.Temp.°C
°C    %   Â°C   Â°C
55.8   0   34.2   76.5
55.8   0   34.2   76.5
55.8   0   34.2   76.5
55.8   0   34.2   76.5
55.8   0   34.2   76.5
55.8   0   34.2   76.5
55.8   0   34.2   76.5
55.8   0   34.2   76.5
« Last Edit: 30 December 2011, 00:40 by mrapoc »
Offline Steve_PD
Re: Vagcom results
« Reply #1 on: 29 December 2011, 19:45 »
To get accurate data you need to do a WOT (Wide Open Throttle) in 3rd gear from as low down as you can to near enough red line.
On the data front am not much use but Rhyso, Topher, Nick (R-tech) or one of the chiptunning guys will be able to help
Be worth putting a post in the garage section as well.
Offline Rhyso
Re: Vagcom results
« Reply #2 on: 29 December 2011, 19:52 »
As Steve said, WOT in 3rd from approx 1500rpm to the redline and repeat at least 3 times to build up an accurate picture
You actual figures should near enough match the figures specified by the ECU  :nerd:
You'll see low down that the boost will not match the requested as the turbo is spooling up; once up and running your boost and MAF levels should be hitting the requests of the ECU
Crap MPG normally points to a failing MAF
What engine is it?
Offline mrapoc
Re: Vagcom results
« Reply #3 on: 29 December 2011, 20:16 »
So to do the WOT in 3rd, just a nice flat bit of road where I can go from 1.5k up to red line recording the same data I have above?
What engine is it?
Ok ill go measure the same blocks/data only this time repeat it a few times in 3rd, on flat land up to red line.
Its a Golf IV GTTDI 1.9 AJM 115.
Just to clarify..I do this on flat roads in 3rd? I remember reading it needs to be a hill or does it not matter.
Thanks very much
Oh and blocks 3, 8 and 11 correct?
« Last Edit: 29 December 2011, 20:43 by mrapoc »
Offline Steve_PD
Re: Vagcom results
« Reply #4 on: 29 December 2011, 21:05 »
yep flat roads and as Rhyso said try to do it 3 times to get some good data.
think its 3 for maf, 11 for boost not sure what 8 is
Offline mrapoc
Re: Vagcom results
« Reply #5 on: 29 December 2011, 22:51 »
Here's the goods. I had to stop and turn around inbetween goes but I went up to the limit and started at about 1.5k.
Offline mrapoc
Re: Vagcom results
« Reply #6 on: 30 December 2011, 12:17 »
Does the MAF readings look dodgy? If so i can go order one today.
thanks guys
Offline mrapoc
Re: Vagcom results
« Reply #7 on: 30 December 2011, 12:59 »
Also, do I see my turbo overboosting?
Offline Steve_PD
Re: Vagcom results
« Reply #8 on: 30 December 2011, 13:23 »
yes your turbo is overboosting but it will always over boost a little.
I would have thought your maf reading look ok as they hit the targets but wait for someone with more experiance to make a comment :lipsrsealed:
What engine is it?
Offline mrapoc
Re: Vagcom results
« Reply #9 on: 30 December 2011, 13:27 »
In the meantime i'm going to repipe my vacuum lines. They look crap
