Author Topic: Rear Axel Bushes help  (Read 4331 times)
Offline richw911
Re: Rear Axel Bushes help
« Reply #10 on: 28 December 2011, 19:20 »
also in the first link it says that early mk4s were fitted with 69mm but 72mm should fit, mines S reg so will those bushes in the link defo fit yeah before i buy them?
Yes  :cool:
good good, cause otherwise ive just wasted 20 quid on them   :grin:
 :grin:
Offline Knacker
« Reply #11 on: 29 December 2011, 00:04 »
Hmm Iv been quoted £165 for parts and fitting with MOT or Do I save the money... :huh:
Offline mcgee9t2
« Reply #12 on: 31 December 2011, 15:48 »
ok, ive got started on this, and got stuck :D after much strugle getting the bolts out that were very rusted, i started to drop the axle, but can only get it to drop about an inch, i think i see the problem, but havent any idea how to sort it so any help welcomed.
this shows how far im able to drop the axle.
what i think it is is this...
what looks like a break line, however i see no way to unclip it? ive uncliped the one that runs under the axle bush, but i think this line is stoping me droping it further, any idea of how to unclip it???
cheers
Offline Dave_IOW
« Reply #13 on: 31 December 2011, 15:56 »
Hmm cant remember from when i did mine, but i ended up taking the rear beam off altogether!
I needed to press my bushes in anyway (polybush) and upgraded all my brake lines to braided at the same time.
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline Dave_IOW
Offline mcgee9t2
« Reply #15 on: 31 December 2011, 15:59 »
http://www.golfgtiforum.co.uk/index.php?topic=205144.0
already read that mate, ive done exactly what its got written in there but cant seem to get it to drop more than an inch. think its because of the line in the background of the pics i posted... though cant see anyway to unclip that  :undecided:
Offline Dave_IOW
« Reply #16 on: 31 December 2011, 16:25 »
Don't think the metal ones can be unclipped but the rubber ones can, im pretty sure if you leave the rear beam on, you wont completely clear the mounting so you wont be able to see clearly through the mounting.
Its for this reason i removed the rear beam!
Best of luck  :lipsrsealed:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #17 on: 31 December 2011, 16:44 »
Take the mount off the floor!
Offline mcgee9t2
« Reply #18 on: 31 December 2011, 16:52 »
thats what i was thinking of doing, however in the thread it didnt look like he did so was hoping i was just making a stupid little mistake, job for tomorow then, just hope these jacks that are holding the axles up dont get niked  :grin:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #19 on: 31 December 2011, 17:01 »
if you're leaving the beam on you have to unbolt them really  :wink:
