Author Topic: clutch slippage and wierd noise. UPDATE  (Read 3462 times)
Offline sprout99
« on: 27 December 2011, 19:15 »
my clutch has started to slip...... :sad:
it's not been in long so you can imagine i'm not amused.
i have noticed a dump valve type sound when changing gear
so will check i don't have anything going wrong.
ca is running very well at minute aswell. obviously too well.
i have a few items to eliminate
1. running winter tyres - temp quite warm so is the rubber too sticky?
2. Been using V power derv - revert to std
3. Remove Pipercross filter
if it doesn't stop will have to get the remap turned down ....again
GRRRRR
« Last Edit: 31 December 2011, 20:37 by sprout99 »
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
Offline Steve_PD
Re: clutch slippage and wierd noise.
« Reply #1 on: 27 December 2011, 19:27 »
Mines always made the dumping noise, dont know why but its always made the power :undecided:
Winter tyres should be used in temperatures below 8c otherwise they will wear down quicker. Its a soft rubber anyway its how they grip on snow and ice.
http://www.youtube.com/watch?v=zLMwF5WR-us
Dont see the point in running v power, I never saw any difference apart from my wallet.
Offline sprout99
« Reply #2 on: 27 December 2011, 20:22 »
it's been spot on until couple days ago.
i swapped wheels to save my RC's from the salt. I hope it's just the super soft stcky winters
causing the problem.
I've been filling up with V power to save wait on a lunch time from work
the extra £2 to fill up saves the 3 car deep wait.
Oak green mk2
V50 D5 Sportwagon
Offline Toby
  • Car - less
« Reply #3 on: 27 December 2011, 20:26 »
If the clutch has started slipping? Surley it will only get worse?
Currently down under
Offline sprout99
« Reply #4 on: 27 December 2011, 20:29 »
the clutch was only fitted 3 months ago.
 :cry:
Oak green mk2
V50 D5 Sportwagon
Offline Toby
  • Car - less
« Reply #5 on: 27 December 2011, 20:37 »
Ooh :/ you sure it was new?  :angry:
Offline sprout99
« Reply #6 on: 27 December 2011, 20:44 »
yup - i bought it and got old one back. It was fitted by dads mate.
i could get the map turned down a bit.....but been great up till now
Oak green mk2
V50 D5 Sportwagon
Offline sprout99
Re: clutch slippage and wierd noise. UPDATE
« Reply #7 on: 31 December 2011, 20:40 »
the join between gearbox and engine is damp......crankshaft oil seal ?
« Last Edit: 31 December 2011, 20:49 by sprout99 »
Oak green mk2
V50 D5 Sportwagon
Offline sprout99
« Reply #8 on: 04 January 2012, 15:59 »
going to get her box out tomorrow
i hope this is something simple
 :undecided:
Oak green mk2
V50 D5 Sportwagon
