Author Topic: coooooold brrrrrr  (Read 986 times)
Offline gavgtiturbo
coooooold brrrrrr
« on: 27 December 2011, 18:42 »
Got in the car today and the heaters cold,any ideas???? Temp gauge sits normal and the thermostat is new,took it for a good run and still cold    PLEASE help  :sad:
Im going to change the temp sender asap but i dont think this should have anything to do with the heater temp.
Offline Hulmie
  • White MK4 1.8T AGU K03s
Re: coooooold brrrrrr
« Reply #1 on: 27 December 2011, 18:54 »
water pump failure? no sign of head gasket gone?
Offline gavgtiturbo
« Reply #2 on: 27 December 2011, 20:18 »
Just got back from the shop,it got up to temp on the way back and its blowing warm again now?? no sign of the head gasket gone,and im guessing if the water pump was nackered it would stay cold  :undecided:
Offline Hulmie
« Reply #3 on: 27 December 2011, 20:27 »
If the it is still the original water pump then over time these go and the propellers wear away or break off. It can still blow warm sometime
Offline gavgtiturbo
« Reply #4 on: 27 December 2011, 20:39 »
Is there anyway of testing it,i dont want to change it if i dont need too  :undecided:
Offline stevelfc
« Reply #5 on: 27 December 2011, 20:49 »
have you got a air lock in the system ?
« Reply #6 on: 27 December 2011, 21:02 »
Could be an air lock or blocked matrix
