Author Topic: Can't close the bonnet  (Read 877 times)
Offline bonny
« on: 27 December 2011, 16:36 »
Can't close my bloody bonnet  :angry: It just won't catch to lock it in!
Any advice??
The more you pay The faster you go.....
Offline stevelfc
Re: Can't close the bonnet
« Reply #1 on: 27 December 2011, 16:52 »
check bonnet release handle inside car is int it closed postion as this sometimes are the problem
or the locking cam is stuck - look in the hole where the bonnet catch fits. Stick a smallish screwdriver in and you will probably be able to flick the cam back into its normal position. It took my m8 ages to work out what was wrong with is .
Offline bonny
« Reply #2 on: 27 December 2011, 18:30 »
Cheers i'll have a look  :smiley:
Offline bonny
« Reply #3 on: 27 December 2011, 20:59 »
Bonnet release was ok not sticking at all, bonnet catch was working ok so i dont know what's goin on with it  :undecided:
Offline bobbieboy69er
  • MK4 1.8T AUM
« Reply #4 on: 27 December 2011, 22:12 »
same thing happend when i first got mine, get some decent lube on it, then you have to make sure the leaver is all the way out and give it a good slam.  do that each time and you should be fine
MK4 1.8T AUM|30mm Eibach Springs|Milltek cat back|4mo rear valance|pipercross filter|R-tech Stage 1 Remap|Baileys DV|Powerflex Front and Rear Bushes|312mm Front Brakes|Creation Motorsport TIP and hoses|17" TT Ronals|  220BHP
