Author Topic: help!!pls heater blows hot & cold  (Read 1069 times)
Offline mcdoobz
« on: 26 December 2011, 21:01 »
hi got a mate whos got this prob with his mk 4 golf,  noticed that when the heater is set on high temp,it blows hot air when car on the move but as soon as he stop and engine ideing, then heater starts to blow cold air ....when he pulls of again heater starts to blow hot air .....so on and so on can anyone tell me what the problem is thx dudes :cry:
Offline shaft69
Re: help!!pls heater blows hot & cold
« Reply #1 on: 26 December 2011, 21:57 »
Usually other way round but check system bled properly and no leaks and there's flow at header tank. If all ok put stat and switch in not expensive.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #2 on: 27 December 2011, 10:18 »
is he noticing any problems with the temp going up and down? Could be a sign on needing a new water pump as the fins may be knackered and its not circulating the coolant round the system when at stand still but when moving there may be enough to circulate some coolant round the system
