Author Topic: 35mm springs on standard shocks  (Read 1861 times)
Offline Ninja
  • 19 smiles per gallon
« on: 26 December 2011, 16:03 »
Is this a sensible idea?
Had a cracking offer (£35) for some 35mm springs, but can not afford shocks.
Am I a tool for suggesting this? Shocks are fairly old but in good condition.
Offline mcgee9t2
Re: 35mm springs on standard shocks
« Reply #1 on: 26 December 2011, 16:15 »
will work but when you jack the car up they will slip out and you will have to fanny around putting the spring back in position while trying to jack the car down. will also make your shocks ware much faster.
its up to you weather you do it or not, why not just buy the springs and either put them on or leave them in storage untill you can afford some new shocks or a pair of decent second hand ones come up cheep.
Offline Ninja
« Reply #2 on: 26 December 2011, 16:22 »
Argh  :undecided:
was hoping it'd be ok. Right might have to find some shocks.
Offline Deano2711
  • 1992 VR6
« Reply #3 on: 26 December 2011, 16:26 »
How will the spring slip out ?? The spring will only move or slip out when compressed. I lowered mine 40mm on standard shockers and had no trouble whatsoever. Never heard of springs slipping in my life !!!
Offline mcgee9t2
« Reply #4 on: 26 December 2011, 16:38 »
if you jack it up the shock is used to a spring of x amount so the spring stays in place were as if you have a shock of x-30 there is going to be 3cm diff between the shock and the spring, doesent always slip out but it can as happend to my mate in sainsburys carpark when he tried to change his wheel after a flattie.
doesent slip out asin its laid on the floor, just doesent sit corectly on the shock due to the amount of play between shock and spring, all you have to do is use one hand to hold the spring in correct place as your jacking it back down and wownt slip out when driving cause of the weight of the car.
could be wrong and that vw have a different type of shock but on a few cars ive seen running standard shock and lowering springs they can slip out when jacking the car up
Offline Deano2711
  • 1992 VR6
« Reply #5 on: 26 December 2011, 17:39 »
From memory when fitting the springs there is a cup they sit in.
Offline dom
  • Back in a Mk4
« Reply #6 on: 26 December 2011, 17:39 »
They'll be fine! :wink:
I really don't see the spring 'slipping out' :grin:
Offline Paul81
  • 2002 GTI Turbo
« Reply #7 on: 26 December 2011, 20:01 »
The Gti is already lowered 20mm as standard so they will only be 15mm shorter.
Am I right?
Mods - Tinted windows, Mk8 Polo aerial, BBS RS2 alloys, -40mm Koni springs, Bilstein b4 shocks, VRS steering wheel, anni roof spoiler, R32 front bumper, rear anni valance, R32 side skirts.
« Reply #8 on: 26 December 2011, 23:52 »
They will not slip out as such but when the car is jacked up they can become loose as they are shorter, this can fail a mot.
Your better off fitting a set of shocks as well really, if you look at the work involved it is not worth doing it twice.
Offline filthy
« Reply #9 on: 27 December 2011, 17:56 »
The only time I've ever seen springs fall out is when they have been cut- proper lowering springs don't fall out or even become too loose....
Having trouble keeping it on the straight and narrow?  www.powersteeringstore.co.uk
